Help! Battery blunder. No radio now!
Old Jan 31, 2005 | 01:24 AM
kingmatt16's Avatar
97 E420
OK it's 5 degrees here. Left lights on, battery died. Went to jump it with a battery booster box, and it was wired backwards. So, I had the connections reversed and the cable attached to the positive terminal of the battery was so hot when I took it off it burnt my hand. I stuck my hand in a pile of snow, reversed the connection and it jump started up no problem. Now I have no radio. There is nothing on the screen and it does not accept or ask for the "radio code". I may have burned out a fuse or two perhaps? Which fuse by the battery is for the radio? I don't have the original owner's manual so I don't know what is for what? Is there any other fuse I should be checking? How much damage COULD have been done??? Thanks for all your help!!!
Old Jan 31, 2005 | 09:06 PM
BenzVince's Avatar
09' E350, 01' Maxima SE, 93 Nissan Maxima SE, 1987 Nissan Maxima SE
You may not cause any electrical damage, however any given time when a battery is disconnected, it's always gonna ask for a radio code. It's a feature in case if a battery was cut out or attempt to steal the radio. I'm sorry to hear that you burned yourself, I hope you're okay. Thank god you didn't have a electrical fire that would burned your entire car.
Old Mar 8, 2005 | 09:21 PM
kingmatt16's Avatar
97 E420
next problem.....
Now the asr and abs lights come on when i hit the brake after i start the car. I then have no brake lights whatsoever. ALl other lights work. Radio still doesnt work. What should I check...please help.
Thanks,
Matt
Old Mar 9, 2005 | 09:02 AM
bryanm's Avatar
CLK320
You effectivly hooked all your electronic up reverse-polarity - not good, not good at all.
If your lucky, you may have only blown one or two modules; I think you need to visit someone with a StarDiag system.
Old Mar 10, 2005 | 08:01 PM
kingmatt16's Avatar
97 E420
good news
I replaced the brake light switch and it fixed the abs/asr lights and now my taillights work. Then I replaced the fuse on the back of the radio and now it works. It looks like I didn't do any permanent damage to my baby with what could have been a electrical nightmare situation...
