Slight vibration right to left in steering wheel
Old Feb 18, 2005 | 07:16 AM
MB Enthusiast's Avatar
1997 E 320 - 2000 S500
I have a 1997 E320 with 162,000 on it
I am getting a slight right to left motion in my steering wheel between 45 and 55 mph
Has anyone experienced this problem?
Has anyone fixed this problem?
Old Feb 18, 2005 | 08:56 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
I would start by having your tires balanced.
Old Feb 18, 2005 | 12:38 PM
rob_fed's Avatar
W204 C300 2010
Look at the outside tread wear pattern of your front tires. If they are wearing unevenly, with the outside tread being cupped or having hi's and low's in the tread blocks, this is probably what you are feeling in the steering wheel.
Per the last suggestion, you may want to get the front tires re-balanced. Ensure that you request a full balance job in "dynamic" mode. Most shops do this for stock wheels, but for aftermarket wheels, most people want all of the weights on the inside of the wheel, as not to be seen on the outside rim edge. You can still get a "dynamic" job with the weights on the inside, but you will need to explain to most of the shops exactly what you want.
Also, if the tires are cupped too much, even a re-balance job will not fix all of the vibration. If the tires are directional in tread pattern, you may need to have the right tire mounted to the left side and the left to the right to put the bad tread on the inside. Worst case, you may need new tires to cure this problem.
Old Feb 18, 2005 | 12:42 PM
OceanView's Avatar
W212 & W210
I also agree with the previous posts.
Check the tire for uneven wear and then get the tires rebalanced.
Old Feb 20, 2005 | 07:59 AM
New Tires balanced Properly
I just put new pirrelli 210 snow tires on and I had the same problem with my Michelin sports.
The wheel moves slightly left to right not vibrating up and down.
I was thinking some kind a wear like a bushing but none is obvious
Old Feb 20, 2005 | 07:39 PM
VMotoring's Avatar
BMW
Check the balance of your tires, one of the weights probably fell off. Should cost you no more than $5-10.
Old Feb 22, 2005 | 01:00 PM
okc329's Avatar
1997 E320 (silver/black)
Front Lower Control Arm Bushings
I had this problem and it continued thru a tire replacement and careful re-balancing. Turned out to be the front rubber bushings in the lower control arms. Common problem on these cars. Dealers used to force out the old bushings and press in new ones. My dealer broke his $1300 press tool on mine so he replaced with new control arms with bushings already in place. I saw somewhere the other day that this is now the standard fix. One point to be aware of : the final tightening of the bushings must be done with the full weight of the car on the suspension otherwise bushings will not be on non-torqued state when car is stationary.
Old Feb 23, 2005 | 07:30 AM
Do you have an estimated cost
What did you pay for the repair?
