E-Class (W211) 2003-2009
I hear clicking sound from the engine when it is cold.
Old Apr 8, 2005 | 02:17 AM
lpolo's Avatar
MBenz
Guys, I heard clicking sound from engine, especially when the engine is still cold and around 1200-1300rpm. But when the engine is warm enough, the noise is a little reduce. Is this normal? Should I bring this to the dealer?
Old Apr 8, 2005 | 10:00 AM
liz's Avatar
liz
had a ticking problem in the foward, driverside part of the engine. It could be heard clearly. the sa said it was due to the abs system. After the cold months, it was still there, I asked him to have the tech check it out. They found that the "purge valve" was making the noise. Part #000-470-35-93. It was replaced and the ticking stopped. Hope this helps.
