DIY : Mesh screen grill
Things needed :
1. Mesh screens (the ones used for windows) from Home Depot
2. 8 plastic clip tie also from Home Depot
3. 3M heavy duty double side tape. Home Depot
4. sizzors for cutting the mesh.
First cut out a piece of mesh the size covering the entire grill. Don't worry about the shape, we'll trim it after it is mounted onto the grill.
Then it's time to put the mesh screen onto behind the grill. Using the 6 hex screws that holds the grill to the hood, you'll need a 5/16" socket to remove the bolts. Just cut a little hole in the mesh then the bolt will go right through. 3M tape is used to hold the mesh in place.
Here is where the 6 bolts are that will hold the top of the mesh up. Don't worry about the uneveness of the mesh, we'll trim it after it is all done.
For the bottom and middle we'll use the 8 clips to secure it to the grill. On the bottom part of the grill there are 2 square opening with a circular opening that is perfect for tie down the mesh.
Here are where the other 6 clips goes from the front of grill.
After pics of the grill when it's all done.
Not sure if any of this is applicable to the W211 - but might be something to look out for.
You should have asked.....
Next DIY I want to start tinkering on upgrading the speakers for my HK system.
