E-Class (W211) 2003-2009
Replace rotors or not when replacing pads
Old May 9, 2005 | 06:13 PM
rdtjr's Avatar
2003 E500
Had my tire guy (Nortown Automotive Chicago) check the brake pads when he was replacing the tires last week. He said there was some pad left but not a lot. He recommended replacing the rotors when replacing the pads and he does not think it worthwhile to attempt machining them. He would charge about $900 for both axles.
Talked to my service advisor - who is also the service manager - today while the car was in for a D+ service and he said they would just replace the pads. He said it was about $650 for the pads on both axles.
Anybody have any thoughts on this? I searched and did not find anything on point. Of course, no guarantees from either if a brake maintenance will stop the squealing. I hate to shell out any extra money on this car if I don't have to as I will keep it less than another twelve months.
Old May 9, 2005 | 06:34 PM
BudC's Avatar
2011 E550, 2013 GLK
You don't turn Mercedes rotors. For one thing, it's so easy to change the rotors that you might as well go ahead and replace them.
On older Mercedes, rotors could last up to 90,000 miles or close to it. Now that Mercedes are using the SBC braking system, rotors may wear our more quickly.
Front brake pad sets for the current E320/E500 cost about $93.00 if purchased over the Internet. Rear pad sets cost about $62.
The two sensors cost about $12.
The only thing that's unusual about changing pads on the current E-Class is that the SBC controller has to be disconnected before you can work on the brakes. Once you've done that, changing pads are easy.
Taking the worst case scenario assume that it takes a dealer two hours at $100/hour plus about $175 for parts. That's less than $400. If a dealer can't change the pads in two hours with a hoist and impact wrench then something is wrong.
Don't change the rotors unless they've worn below the minimum acceptable thickness according to Mercedes.
Try searching this forum to find Info from people who have done the work themselves.
Old May 9, 2005 | 09:04 PM
pkancel's Avatar
03 E500, 2010 E350, 2006 550i
Brakes
Guys, watching these threads and wondering, doesnt Mercedes include the brakes in their free service plan? I have an 03 E500 and going in for a few things tomorrow. One being brake squeak, so are not the pads and potentially rotors covered?
BMW covered this so I assumed Mercedes does too!
Old May 9, 2005 | 09:15 PM
BudC's Avatar
2011 E550, 2013 GLK
No, wear items are not included. The so-called free service amounts to a value of no more than $300 assuming that the most you will get is three oil changes and a couple of filters. In fact, it works out to the advantage of the dealers because they get you into the shop for the *free* oil change and find other things that they'll charge you $100/hour to work on.
Old May 9, 2005 | 09:19 PM
Kar don's Avatar
Mercedes-Benz
this is why they eliminated the free service, to cut costs and complaints over what it covers. They may cover pads if it is a break squeak not related to wear.
Old May 9, 2005 | 11:49 PM
HELL ONA HARLEY's Avatar
Build date 2-04 E500
Why go against the word of your SA and change the rotors at your exspense??? If your SA says the rotors are fine then leave them alone. Just make sure that he knows for sure that the new pads will out last the "old" rotors and have them note it on the service agreement.
Old May 11, 2005 | 03:21 PM
benzboy's Avatar
SL500 E320 ML350
I just had brakes done on my '03 E500. Sounds familiar - my tire guy said the front pads looked low so I had the dealer check them out. Fronts (at 26,400 miles) were down to 30% and he said the rotors were fine. I had front and rear pads done and they charged $442. Seems fair to me.
Old May 11, 2005 | 06:03 PM
JimPurdy's Avatar
11 ML350W2 / 17 GLC300
It sure seems like the tire places have a lot of price competition for tires and thus have somewhat low prices for the tires. They then seem to "find" things to fix or replace at very high prices. Since they aren't building a long term relationship with the customer, they don't seem to care that they are overcharging for some services. I have heard similar stories where the tire / battery / etc. place charged more than the dealer for a service that may not have even used OEM parts. I personally check with the dealer for an estimated cost before allowing someone else to service my vehicle. On another note, watching some of the tire places lift the car can be very unnerving. There are places to jack the car and when the jack points of the lift aren't placed correctly, the car may be damaged. There is one place that I will not allow to lift my car unless they let me adjust the lift.
Old May 11, 2005 | 08:26 PM
RJC's Avatar
RJC
Various
MB covers brakes (pads and rotors for things like squeals and squeaks) for the first 12,000 miles...
Old May 15, 2005 | 09:14 AM
LAZARU5's Avatar
2025 E53 Hybrid
Deactivating/Activating SBC
How complicated is it to deactivate and then re-enable SBC when doing brake maintenance? Can this be easily done by a DIY mechanic?
Old May 15, 2005 | 09:24 AM
SPIKES's Avatar
2019 S63 COUPE
i read somewhere that you just unplug it at the unit in the engine bay. do a search under brakes in this form.
