Heeelp, urgent - pumped regular gas....
I was in a rush at the gas station and didn't notice that I selected regular gas... I only pumped like 6 gallons and then switched to premium (for another 12). I panicked so I also poured in one of those ATP fuel cleaners...
Can someone elaborate on the obvious question "what did I mess up?". I also had to bring the car in to the dealer (to have my aftermarket xenons progammed) and I noticed some rough idling so I mentioned it to them. They said that "something is misfiring in there" so they'll look
I can't remember if that started before or after pumping the gas but hopefully it's not related to the gas issues.Any comments, suggestions would be highly appreciated.
Thanks guys,
Sergiu
The problem here is that people assume that cheap gas in DIRTY. If you buy low-octane gas at a reputable station it will be just as clean as the premium fuel. Fuel grades are referring to the octane rating, not the cleanliness of the fuel.
At the same time, there are very few fuel injector cleaners that Mercedes Benz approves for use in their vehicles. I have never put anything other than 44k in my cars. I have had really bad experiences with other brands in the distant past. Some people even report having fuel gaskets and injector damage from some cleaners. You hopefully will not have any permanent negative effects of the cleaner, but I would be willing to bet that the missing/misfiring is from the injector cleaner and not the cheap gas.
There should be no damage from the occasional cheap gas use as long as you don't give the car hell when it has cheap gas. I always get premium, but only if I can not help it I sometimes get whatever the place sells.
Good luck,
Steve
Your question here reminds me why I don't even consider lease returns if I had to buy a used car. I am sure that you are not the only one who is contemplating or doing this. Prolonged use of cheap gas would probably do some damage to the engine like excess carbon deposits and stuff. This is penny wise and Dollar foolish.
Steve
I hope your service advisor does not make an issue of you putting in the 'cleaner'. It sounds like there is indeed a problem which needs to be sorted.
Good luck,
John
