E-Class (W211) 2003-2009
E320CDI vs E350 brake calipers
Old Jul 19, 2005 | 12:40 PM
CE750's Avatar
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
I just noticed that on my '05 CDI and on my '06 E350 (that my mom has in CA) the brake calipers look different. Her's look better, and say Mercedes Benz on them, while mine look kind of generic... is there an actual difference in them, or is it all cosmetic?
Can the '06 brakes be installed on an '05? I rather like the way they look better.
Old Jul 19, 2005 | 01:38 PM
baubaulu's Avatar
E350 Sport Package
The one with MB logo is the four piston break system. The regular one is two piston break system.
Old Dec 1, 2005 | 10:57 AM
rubensans's Avatar
Brabus K3
Rears are also different?
Old Dec 1, 2005 | 12:43 PM
SteveBC16's Avatar
Veteran: Army
2019 E450 4Matic, 2018 E400 Coupe
E350 Brake Calipers
The initial batch of E350's were produced with the following brake configuration:
Front - 13.0" ventilated - 4 piston fixed calipers
Rear - 11.8" ventilated - single piston floating calipers
Sometime after June or July they started to ship with the same brake configuration as the CDI:
Front - 12.3" ventilated - single piston floating calipers
Rear - 11.8" solid - single piston floating calipers
I assume that this was all part of a cost cutting initiative by MB.
I was also told by MB that, due to the design of the AWD system, all 4 Matic versions of the E class are produced with the single piston front calipers. I raised this very question when I took delivery of my E350 4 Matic and noticed that the front calipers used a single piston.
Good luck,
Steve
Old Dec 1, 2005 | 01:43 PM
aceman's Avatar
E500 4matic, 2014 GL320, 2013 C300, 2015 Stingray
interesting...
And the just announced 2006 sport package upgrades all routers to drilled style with MB logo calipers (per their website - there's a pic).
Aceman
Old Dec 1, 2005 | 01:53 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
One can Upgrade to the SLK55 Brakes..Front and rear! they will fit..Six piston calipers up front....Looks Great!
Old Dec 1, 2005 | 01:58 PM
AJU_E350's Avatar
I remember reading a thread about the "cheap" breaks they used in the E350... and I always thought mine seemed different. Maybe thats why... mine have the MB logo.
Old Dec 1, 2005 | 01:59 PM
mbchris's Avatar
Interesting
Is this part of the decontenting? Or were there problems with the 4 piston ones?
Which are better brakes?
Old Dec 1, 2005 | 02:17 PM
AJU_E350's Avatar
Do you have any pics of these ? Did you do this swap on your E yet?
Where can you buy them???
SteveBC16's Avatar
Veteran: Army
The 4 piston calipers are a higher performance brake and, given their design, are more expensive to manufacture. They are, BTW, standard on the E500.
Old Dec 1, 2005 | 05:08 PM
rubensans's Avatar
Brabus K3
Then you can upgrade E brakes to:
E55 (Direct bolt on) (18' AMG or 19')
8 pistons front
4 pistons rear
SLK 55 (Are they direct bolt on?) (18')
6 pistons front
4 pistons rear ?
Best Regards.
Old Dec 2, 2005 | 01:04 AM
CE750's Avatar
The former alas. My mom's E350 came standard with 16" wheels and 4-piston brake calipers in front.. Build Apr 2005.
BTW.. Mark.. how much did the SLK55 brakes cost you to install/parts etc..?
Old Dec 2, 2005 | 01:49 PM
AJU_E350's Avatar
How come my wheels are 17 inch?
Old Dec 10, 2005 | 02:15 AM
akbro93704's Avatar
2014 C250 sport
Our E350 is a 9/05 build, has the single piston w/ 17" wheels. To answer AJU_350's question, I believe the 17" wheels were used starting in June. What's the build date on your car? Your's could be one of the few w/ 17" and 4 piston
Old Dec 12, 2005 | 11:11 AM
rubensans's Avatar
Brabus K3
Any pics?
Old Jan 18, 2006 | 03:05 PM
rubensans's Avatar
Brabus K3
Thumbs down
I'm sorry but they don't fit.
I have buy the brakes of the SLK AMG and they don't fit.
1.- Backing plates needs to be cut or changed to SLK ones, you can bend them but it's not enought.
2.- Disc holes for bolts on SLK are 13mm because wheel bolts are 12mm; in E disc holes for bolts are 15mm because wheel bolts are 14mm. So you have to make the 13 mm bolts larger to 15mm so the wheel bolts can enter.
3.- The SLK discs are more to the outside than the E ones, then the caliper is too much inside. You have to do new caliper mounting brackets so you can center the callipers with the disc.
4.- Calipers touch 2 mm the suspensión arm. Maybe this is only on airmatic's, but you have to sand 3mm the inside corner of the calliper.
I don't see the way they can fit without big modifications. Are you sure your friend put the SLK discs on a E? I know they are compatible the SLK and CLK, but it's sure that they aren't with E.
Now the problem will be manufacturing new mounting brackets.
Best Regards.
Old Feb 7, 2006 | 10:12 AM
rubensans's Avatar
Brabus K3
You also cannot put rear SLK/CLK 55 brakes because:
CLK/SLK 55 Rear calipers are leading and E55 rear calipers are trailing.
Best Regards.
Old Feb 21, 2006 | 06:06 PM
rubensans's Avatar
Brabus K3
I finaly succed to install SLK 55 FRONT + E55 REAR.
E55 REAR are plug and play.
SLK55 Front need a lot of work.
Best Regards.
Attached Thumbnails E320CDI vs E350 brake calipers-web1.jpg   E320CDI vs E350 brake calipers-web2.jpg   E320CDI vs E350 brake calipers-web3.jpg   E320CDI vs E350 brake calipers-web4.jpg   E320CDI vs E350 brake calipers-web5.jpg
