W211 Fuse Positions anyone?
2003 E500
Okay, without going into too much detail, had electrical problems with my car (alarm going off and not being able to turn off with key) error code in dash that makes fuel gauge unreadable as well as no turn signals, and to top it off, I couldnt get the car to unlock with the remote or the valet key, so I opened the trunk, flipped the fold down seat and squirmed my way into the car to unlock the doors. After I did that, I went outside the car to close the trunk and now my trunk wont stay closed. Have no idea why this happened, but I started pulling fuses to check them and realized I have some in the wrong place now. Can anyone PLEASE open thier trunk, pull the trim piece on the left hand side and then pull the plastic cover over the fuse block and tell me the fuse listing for the car? I live about 300 miles from the nearest dealer and it would help me a ton to get the fuse position straightened out before I go to the dealer. Alll I need is a quick reply like "spot 6 8 and 10 have no fuses, all the rest are filled." or something like that. They are all numbered so It should be easy for someone to write down the numbers of the empty fuse slots and post them here. Thank you so much for any help...
'03 Mercedes E320
I don't have access to the car today but isn't there a paper schematic folded up in the fuse panel on the dash side panel, or perhaps inside the relay box under the hood? I have seen it somewhere.
2003 E500
I was wondering the same thing, but havent found it yet. Ill look under the hood and the side access panel in the drivers side door. Thanks.
Geoff
Geoff
2015 ML 350
Where YOU have fuses & where You don't is also dependent on the options in YOUR car. No option=no fuse. Also check the owners manual, every other vehicle manufacturer lists a map/fuse size in their manuals.
2003 E500
Thank you for the picture. I have other problems with the car, but I wanted to make sure when I took it to the dealer at least the fuses were in the right spot. I understand the previous posters explanation regarding different fuses for different options, but I at least wanted a basic fuse layout and you provided that perfectly. Once again, thank you.
Geoff
Geoff
