E-Class (W211) 2003-2009
E320 Mercedes Brake Failure WTF
Old Feb 20, 2016 | 03:16 PM
  #51
rapidoxidation's Avatar
2013 ML350 Bluetec
Originally Posted by kajtek1
e-brake at higher speeds is not more efficient than engine braking.
How many W211 owners know that you can select "1" at 80 mph and the computer will not switch to lower gear till the car slows down to allowed speed.
What stumps me is that W211 do have emergency solenoids that will give you mechanical braking, just like in your Corvette. but in panic - in maneuver you never practice it is easy to mistake hard brakes for no brakes.
Are you sure that's what you meant to say? 'Cuz if so, then I must disagree. Given a choice between a working engine and properly shifted transmission slowing down my drive wheels vs. a manually operated (not solenoid operated, like on many new cars) e-brake, I'll take the e-brake.
A solenoid operated e-brake (either ON or OFF) isn't really an e-brake. It's a parking brake.
Agreed on the electronics of a modern transmission "protecting" the drive train. If the TCM thinks the car will over rev by shifting into the requested gear, it ain't gonna do it.
Old Feb 20, 2016 | 03:49 PM
  #52
kajtek1's Avatar
1922 Ford Model T / no OBD
I did use ebrake once at over 40 mph and could not tell it did anything. Downshifting sure gave good slow down.
Each experience is different, but using really good ebrake at high speeds might end in locking both rear wheels and that is not going to be pretty.
I made it my life policy to test each vehicle with no power.
Take it to empty parking lot, switch to neutral at 20 mph, (higher on 2nd try) switch engine off and try to maneuver it.
It is very doable, but first impression is scary.
Simulating SBC going to emergency mode is a bit harder to figure out and I am still working on it.
Old Feb 20, 2016 | 05:27 PM
  #53
2013 ML350 Bluetec
I wonder if disconnecting the SBC pedal value sensor on the brake pedal hydraulic unit would be enough to trigger the emergency mode...
Back in the day, a manual E-brake lever (worked the rear wheels) on a front wheel drive 5 speedToyota was GANGS of fun on ice covered roads. Yes, yes it was.
I like your "life policy". Makes good sense to know how the car will react to bad situations well before you find yourself unwillingly in a bad situation.
Old Feb 21, 2016 | 01:06 AM
  #54
The Thomas J's Avatar
2010 MB S550, 2017 MB SLC 300
The E brake has to be properly adjusted as well. My BMW has 2 adjustments. One at the base of the brake handle and on the wheel.
Old Feb 21, 2016 | 01:08 AM
  #55
I used to drive a Toyota MR2. The mid engine design combined with the 5 speed was a great combo for spin outs on icy roads and gravel roads. So much fun.
Old Feb 21, 2016 | 02:36 AM
  #56
mersum1es's Avatar
W211 320CDI -04, W210 270CDI -01
Have you tried SBC unit connector plug disconnected? I remember someone said trying that...
Old Feb 21, 2016 | 10:34 AM
  #57
kajtek1's Avatar
No. My understanding is that pulling the plug will also disable emergency solenoids, meaning disconnecting back up as well.
On the other hand, the plug was subject to recall as was giving originally big headaches, so I am not touching it till I am sure this is what I need.
Old Feb 21, 2016 | 10:55 AM
  #58
mersum1es's Avatar
If I recall right, emergency solenoids are energized during normal operation (makes sense if total blackout system is emergency mode)... I am sure I have SBC document saved somewhere but watching sport right now
Old Mar 8, 2016 | 09:36 PM
  #59
jhorandc's Avatar
MB E320
Originally Posted by irishhitman
Just found a local shop... in the town where the (SBC crapped the bed) He got the part from Pelican Exchange made by Bosch for $675.00 will install after bleeding the system and have on the road for $985.00
Guess that beats my MB dealers $3000.00
Was it $985 total including the $675 SBC part?
Old Jul 12, 2017 | 03:00 PM
  #60
skirwe's Avatar
2006 Mercedes E350 4matic
2006 Mercedes E350 4matic brake failure
Originally Posted by moa4r
The brakes failed completely while my mother was driving.
Unbelievable.
Car is a 2003. Nobody in my family is planning on ever getting in the driver's seat of this POS again. How will mercedes handle this? 31K miles, 2nd owner.
I DRIVE A 2006 MERCEDES E350 4MATIC AND JUST EXPERIENCED A CATASTROPHIC BRAKE FAILURE WHILE DRIVING DOWN THE FREEWAY. BRAKES WORKING FINE ALL DAY AND THEN WITH NO WARNING MESSAGES OR NOTICEABLE CHANGES IN CAR THE BRAKES FAILED WHEN I APPLIED THE PEDAL. TRUCKS IN FRONT OF ME, CARS BEHIND, ROAD CONSTRUCTION ON THE RIGHT, CLIFF ON THE LEFT, GOING 65 MPH, THEN NO BRAKES WHEN NEEDED TO AVOID SLOWING TRUCK IN FRONT OF ME. LUCKY ME TO SLIP INTO NEXT LANE, MISS THE TRUCKS AND WENT ANOTHER MILE BEFORE FINDING A PLACE TO PULL OVER. WAS ABLE TO COAST TO SLOW SPEED THEN BY PUMPING BRAKE PEDAL GOT MINIMAL BRAKING UNTIL SLOWED TO A STOP. AFTER THE BRAKES FAILED A "STOP NOW" BRAKE SYSTEM WARNING LIGHT APPEARED IN SPEEDOMETER DISPLAY. YOU MOTHER WAS LUCKY NOT TO GET KILLED.
Old Aug 10, 2022 | 01:00 AM
  #61
Dwayneruark2's Avatar
2003 MB E 320
I have a 2004 e320 with new brakes and thay stopt working all of the sudden going daw
I was driving dawn the hiway and my brake whent out and I all most rear-ended the car in front of me wat if i dide
Old Aug 10, 2022 | 10:10 AM
  #62
tjts1's Avatar
C320
If you dide you'd be doing the world a favor. Please don't breed.
