E-Class (W211) 2003-2009
Door creak
Old Sep 7, 2005 | 11:38 PM
Rudegar's Avatar
2004 E500
Door creak
My driver side door has develeoped a creaking sound at 13,000 miles. Its the same sort of creak my 85 BMW doors had when it was FOURTEEN years old. Any idea what could be causing this in a new car with such torsional stiffness?
Old Sep 8, 2005 | 12:53 PM
Barry45RPM's Avatar
2015 ML 350
lubricate the black check link on the top, the bottom and sides. It will stop.
Old Sep 8, 2005 | 02:23 PM
Rudegar's Avatar
2004 E500
Thanks Barry. Any particular product you would use for the lube?
Old Sep 8, 2005 | 05:08 PM
Barry45RPM's Avatar
2015 ML 350
I use white lithium grease or a clear synthetic (from a tub or a tube, not spray on). Its not necessary to overload the check-link, a little is better than a lot... the squeak will go away in short order, and too much grease attracts particulate dirt, which you don't want to do.
Old Sep 9, 2005 | 10:06 AM
ATS's Avatar
ATS
2004 E500 / 2001 C240
My passenger door had a creak, they replaced something.. Now it is great.
Old Sep 9, 2005 | 10:21 AM
CE750's Avatar
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
Get a can of silicone spray, and use the long red nozzle. and lube your hinges.. that's basic auto maintenance on most cars these days. I would be suspicious if your dealer didn't do it on your last visit. They should also do the sunroof.
