Help, W211 brake pads change
https://mbworld.org/forums/showthrea...=diy+brake+job
The SBC pump.....it is silver in colour about 6 inches square and as several metal brake pipes going to it you can,t miss it when you open the hood.
You will see the wiring harness on the side of the metal box (silver as stated) and also see THE RECALL WIRING FROM M.B (brown in color) if this modification as been done......this wiring as a clip to attach it to the pump.
To remove the harness slide the clip up and pull the harness back from the pump.
PUT THE KEY AWAY FROM YOURSELF AS NOT TO ACTIVATE THE CARS SYSTEM.
Fitting new pads and rotors as same as any other car.
REMEMBER WHICH WAY THE SENSORS FIT INTO THE PADS.
REMEMBER TO PRESS THE BRAKE PEDAL SEVERAL TIMES TO BRING THE PADS INTO CONTACT WITH THE ROTORS BEFORE INSERTING THE IGNITION KEY.
THE JOB SHOULD TAKE YOU AROUND 1 HOUR TO DO ALL 4 CORNERS.
If you are uncertain i will post some pictures
Les Chesterfield England
http://www.whnet.com/4x4/sbc.html
