Seemingly poor mileage from my dizzel...
My CDI was only able to muster about 28.5mpg on a 100 mile drive yesterday, most of which was spent at 90 mph. Even when traveling around 70mph, I've barely been able to break 33 mpg on the highway. Seems like others are getting better mileage out of their CDI's. Does California have crappy diesel fuel too?
Raj
'97 e320
'05 designo e320 cdi
'85 535i
Raj
'97 e320
'85 535i
1 Post
Late Built 2005 W-211 E-320 CDI
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Seems that you're not getting very good mileage indeed .
Are you tires air up properly?
Do you wind it up all the time, or allow the low speed torque to do all the work?
How about second gear starts?
I've found that using second gear to start up from rest in my older 300 DT helps here.
There is no need to wind 'em up. Make that low speed torque work for you.
Don't expect very good mileage at 90 mph!
As far as California fuel is concerned, we have the best in the country.
What brand are you using?
Arco will usually yield a trifle less, but it is really hard to record any difference.
Is this tank average mileage or off-of-the-computer?
With other vehicles over the years, I have discovered that computer
mileages are usually not as accurate as actual tank mileage.
Best to take the averages of several full tanks.
100 mile tests are not at all accurate.
Do you usually fuel up at the same pump with the Designo parked in the same position?
Many are inclined to "stetch" the truth if you get my drift? :p
These are little considerations but can and do make a difference.
Do you really fill it up completely and take the extra several minutes to make
sure that all the bubbles are gone and that the tank is really full each time?
Please keep us posted.
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
06 320E CDI, Porsche 911 C2, Pontiac Montana
Raj
'97 e320
'85 535i
Raj
'97 e320
'85 535i
![wwf](https://mbworld.org/forums/images/smilies/chairshot.gif)
OBVIOUSLY the wife is not pushing hard enough.....
Harley-Davidson
I made a trip to Arizona last month, and saved all of my fuel receipts. In almost 3000 miles of highway driving between 70 and 80 MPH with the A/C on and using cruise control 90% of the time, I got 37.72 MPG.
The onboard computer had calculted my average speed at 61 MPH (I had a small amount of city driving in Phoenix) and showed only 35.6 MPG.
I was pleased to get almost 38 MPG, but was surprised that the onboard computer missed the mark by over 2 MPG.
I'll due a more "scientific" mileage test next time around and post results. If my OBC reads similar to cyclerider's, then I might be getting 30+ mpg @ 90mph!
Raj
'97 e320
'85 535i
1 Post
ML 320 CDI
I think that the gearing is slightly different in the USA compared to Europe but I always manage to get 31 - 33 when cruising at around 90 mph, including any stop starts. Through France I set cruise at 145 for nearly 50 miles and got 24 mpg which I thought was pretty cool.
'05 e320 cdi, '05 lexus rx330
your gallons are larger than ours
In the last 1.25 years, I had TWO diesels E-class that are EXACTLY the same. Here is what I got from both of them in the last year+ and 14,000 miles.
City-Saburban....25-27 MPG,
Highway.....35-36 MPG at 75 MPH. 42MPG at 60MPH
Note: All figures are US mpg.
Note 2: First car had 11,000 miles and second 3,000 miles so figures should improve by a MPG or two after 20,000 miles or so.
Note 3: My highway miles are always done the same way. Set the car at 75 MPH and just sit back, relax and read the newspaper, enjoy a cappuccino. Occasional, I peek over the paper to make some course corrections or pass another truck.
Nope, always leave it in "S" mode. I'm not so sure that 2nd gear starts are good for that clutch pack.
Back to your low mileage problem. Reduce the speed and watch the mileage go up. My GMC 2500HD gets 18mph when I can keep it 65 or under but only 15.5 if I take it up to 75-80.
1 Post
'06 E 350 4matic wagon; '05 E 500 4matic sedan; '09 S550 4matic
You set your cruise control for 145 MPH in France?? What is the limit? I don't think I've ever been in a car going more than 110 let alone cruising at 145!
He's mixing his miles with his kilometers.....the same way I mix sushi with beer......
145 kph = 90mph
1 Post
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
Raj
'97 e320
'85 535i
Raj
'97 e320
'85 535i
At 90 mph I can get about 33mpg... at 66mph I get 40mpg..
But then I have Renntech tuning, and that could play into it..
You should easily be getting the 37 highway at 65mph that EPA got.. I wonder if your California Diesel is low in Cetane? 40 is bare min, and 45 is ideal... I add Redline 85+ additive to every tank... besides adding to the lubricity of the diesel, it also boosts cetane by 4 points for a 1/2 bottle per tank.
1 Post
ML 320 CDI
145 kph = 90mph
145 kph = 90mph
Originally Posted by marc777
This is what my desiel achieved in France. ![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
Thats an average of 75mph for 9 1/2 hours - average mpg (UK) 38mpg.
Marvellous.
Marvellous.
As for the 9 1/2 hours....YIKES....don't you need a bladder brake? Or are you related to the cat family?
2012 CLS
The trip was 9 1/2 hours of driving and the average was 75mph - allowing for pee breaks, fuel, traffic jams, tolls etc etc
Marc
'05 E320 CDI, '07 VW Touareg V10 TDI, 2007 Porsche GT3
Marvellous.
Since you're in the UK, I assume those are Imperial gallons. A US gallon equals .833 Imperial gallons, so your 38 mpg would be 31.6 miles per US gallon.
Our CDI has done 38 calculated mpg on its best tank of fuel (Lansing, MI to USAF museum in Dayton, OH and return) and 32 mpg overall. The Goodyear 18" tires now on the car have degraded the mileage by about 8%, however, so my days of great mileage are over.
Marvellous.
1 Post
Originally Posted by TPAbnz
Do you happen to know what your cetane numbers are?
C A R B has their requirements, but there are various brands that exceed that minimum I'm sure.
I would say that there are many brands that are in the high 40s up to the low 50's.
