E-Class (W211) 2003-2009
Mityvac Product Plug
Old Jan 13, 2006 | 02:57 PM
JimPurdy's Avatar
11 ML350W2 / 17 GLC300
I finally broke down and purchased a Mityvac Fluid Evacuator Plus to use to suck the oil out of the crankcase. This model holds 8.8 quarts so it will hold all the oil at once. There are marks on the side of the reservoir so you know how much oil has been removed. I was amazed at the speed it sucked the oil out. This is certainly a lot easier than removing the belly pans and the crankcase drain plug. When my wife saw how quickly and easily the oil was removed she asked why I hadn't purchased one years ago. The oil removal process was faster than refilling the crankcase with 8 1/2 quarts of oil, one quart at a time.
Old Jan 13, 2006 | 05:30 PM
SUNILP's Avatar
2015 E250D
I have used their products for several years and they are great.
Old Jan 14, 2006 | 02:23 PM
saffrontiger's Avatar
W211 2005 CDI, X166 2013 350 BT, 997.1 2008 C4S
How much do they cost? I may end up buying one.
Old Jan 14, 2006 | 08:04 PM
JimPurdy's Avatar
I purchased it for $59.50 at www.thetoolwarehouse.net.
