E-Class (W211) 2003-2009
Bad MPG when it is cold..
Old Jan 15, 2006 | 08:50 AM
KosherBenz's Avatar
Its big and Grey!
Ive noticed that you get bad mpg until the car warms up. No brainer, But it seems like even when its cold out (like 30's or colder)I am not getting the best mileage. Anyone else notice this?
Old Jan 15, 2006 | 12:30 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
This is true with all gasoline powered cars. Why have you just noticed it now with an MB.
Old Jan 15, 2006 | 12:32 PM
lkchris's Avatar
'10 CL550, '12 GL550
Of course, his is a diesel and the reason is different.
Old Jan 15, 2006 | 12:38 PM
sosh's Avatar
Diesels are even more prone to reduced mileage when cold. I had a pair of Detroit diesels in my boat. In the summer at 2400 RPM they burned 34 Gal per hour, in the cold (below 40 degrees F) they both burned 39 GPH at the same RPM and the same boat speed. They also smoked a lot until they warmed up to 170 degrees but with the colder ambient temp the fuel consumption stayed at the higher figure.
Old Jan 15, 2006 | 03:50 PM
Hattaresguy's Avatar
1987 300SDL aka the "Money Pit"
Winter fuel, when they switch to winter fuel at the pumps you should notice about a 10% drop in mileage. No worries come April or so you will notice it going back up.
This applies only to diesels of course.
Old Jan 15, 2006 | 04:16 PM
khaug's Avatar
'05 E320 CDI, '07 VW Touareg V10 TDI, 2007 Porsche GT3
Actually, the same thing, more or less, happens to gasoline. In cold weather, refineries adjust a gasoline parameter called Reid Vapor Pressure to facilitate starting and running. This costs a small increment of fuel efficiency, although not nearly as much as the drop with "winter" diesel fuel.
Winter diesel fuel contains a higher percentage of lighter distillates which have a lower energy content per unit volume. This change in blending is done to lower the gel point of the fuel so it'll still flow at winter temperatures.
Old Jan 15, 2006 | 05:38 PM
Fastbuck's Avatar
2019 Mercedes Benz S500L AMG Premium Plus
It takes my CDI about 11 miles to get to full operating temp when its below freezing.
