Steering noise
Raja
(1) P-B-46.30/22a APR05, NOISES FROM THE AREA OF POWER STEERING PUMP - Power steering hose check & adjust; Power steering reservoir / lower hose replace if necessary; Power steering operation, check & inspect for leaks; Power steering pump replace.
(2) P-B-46.20/16a APR05, LEAKS AT THE INTERNAL STEERING LINES OF THE CONTROL HEAD CONECTION AND/OR STEERING GEAR HOUSING – Power steering gear box/steering rack replace; Both lines – control head to steering gear housing , seal/replace if required.
