Transmission Fluid Change
This is good to know. I am thinking that I am going to have the ATF changed/flushed or whatever you want to call it at about 20K for the first time. I also will have the transfer case fluid changed at the same time. I kind of thought that this 100K service life was wrong. Also, BudC sent me a service bulletin that MB in Germany issued stating to change the ATF at about 60,000 KM (or about 37,000 miles). Fluid is cheap and just because I have an extended warranty it does not mean that my transmission will fail while it is still covered. I think that this is the way to go if you are planning to keep the car for a long time (which I am).
I will try and find the letter and it's translation and post it. Also, how clean was the fluid going in the machine (the new ATF)? Sometimes the new fluid is already kind of black.
Steve
