E-Class (W211) 2003-2009
sunroof problems
Old Jun 13, 2006 | 03:50 AM
EclassOzz's Avatar
sunroof problems
my sunroof is retarted..i tried to open it this past weekend and its all messed up,it doesnt go all the way back,a couple peices broke off,like when you tilt up the sunroof,the plastic thing that holds it up,anyways my question is,will this be covered by warranty..im assuming so,cuz this is BS,any help is much appreciated,thanks
Old Jun 13, 2006 | 07:04 AM
rodE350's Avatar
2006 E350
that will be covered under warranty....that is, if you still have warranty.
Old Jun 14, 2006 | 04:38 PM
Barry45RPM's Avatar
2015 ML 350
I just couldn't resist this one... its spelled "retarded"
Just messin' with ya!
Old Jun 14, 2006 | 10:33 PM
konigstiger's Avatar
'71 Pinto
Originally Posted by EclassOzz
sunroof doesnt go all the way back, a couple peices broke off, like when you tilt up the sunroof, the plastic thing that holds it up,anyways my question is, will this be covered by warranty..
As a matter of reference P-B-77.20/19b OCT05 Intermittent Synchronization Loss from Sliding Roof or Panorama Roof, model 211 up to VIN A609690 and X165949 – may be the result of the voltage at the overhead control panel (OCP) dropping briefly below 5 volts. Replace the OCP - sliding roof part #A211 820 57 01, panorama roof part #A211 820 60 01.
Can’t answer for the broken pieces nevertheless it should be covered under warranty.
Old Nov 12, 2007 | 02:12 PM
noyu's Avatar
17 E43, 18 GLE400
Sorry for bringing this thread up but do you guys have a copy of the bulletin on the sunroof control unit issue?
My warranty will be expiring on the January 2008 so I want to have all issue fixed before it expires.
Thank you very much in advance!
