Xenons: What purpose do the smaller headlights serve?
I have the bi-xenon headlights on my E. When the headlights are on, however, not only are the xenon bulbs on, but so are the smaller, "hi-beam" lights (the ones closer to the grill that come on when you flash your hi-beams). It's my understanding that with bi-xenons, the xenon lights function as the hi-beam lights. So, other than looking nice, what function do these other lights serve? Are they just there to flash, since xenons react too slowly to do so?
I ask because these lights are more of a stadnard "yellow" color, whereas the xenons are bluish in tint. I'd like to get blue bulbs for these lights (so they'll come closer to matching the xenons), but blue bulbs generally produce a lot less light (even though they look "brighter"), so I won't change them if these lights do something more important.
Thanks in advance.
Thanks in advance.
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Originally Posted by mon-004o
"flash to pass"? That's not correct, "flashing" in Germany is illegal, even on the autobahn at speed.
Originally Posted by RickyEarl
I have the bi-xenon headlights on my E. When the headlights are on, however, not only are the xenon bulbs on, but so are the smaller, "hi-beam" lights (the ones closer to the grill that come on when you flash your hi-beams). It's my understanding that with bi-xenons, the xenon lights function as the hi-beam lights. So, other than looking nice, what function do these other lights serve? . . .
Originally Posted by sosh
I have no clue as to German laws. However the only function that those lights serve on US models is the flash to pass controlled by the stalk when the Xenon Headlights are not on. We are speaking about a US, North American vehicle here.
How about cop-warning indicatator flashers?
A lot of these responses make no sense to me. One of the purposes of bi-xenon lights is to function as both high and low beams (that's what the "bi" in "bi-xenon" means), so it doesn't make sense that MB would use those lights as high beams on the cars with bi-xenon lights. See pp.10-12 of this .pdf by Hella, the manufacturers of the bi-xenons on the E:
http://www.hella.com/produktion/Hell...dern_Light.pdf
So, sosh, is there any reason not to try to "color match" the bulbs on these lights? I may lose some brightness, but it doesn't look like I should care.
Also, why are they always on when the lights are on? Is that just for aesthetics?
Originally Posted by cyclerider
That is unlawful in Oregon and probably most other states as well.
Interesting read on that topic, too:
http://<br /> http://www.tennessean...nt_ID=41877517
A lot of these responses make no sense to me. One of the purposes of bi-xenon lights is to function as both high and low beams (that's what the "bi" in "bi-xenon" means), so it doesn't make sense that MB would use those lights as high beams on the cars with bi-xenon lights. . .
I did a search before posting, but these lights appear to have so many "names." Some people call them "city lights" and some "running lights." Others call them "main lights," which doesn't make sense to me.
Anyway, as long as there's no down side to doing it, I'm replacing them.
It would be better still if they never came on at all unless I flashed them.
I just figured out what my real issue is. I went down to the garage to take a look at it, and it looks like the parking light AND the high beam bulb come on whenever the lights are on. In fact, the high beam lights are on whenever the lights are on, and are so bright I can't see the parking light underneath them at all. I can "flash" with the stalk and the high beam indicator lights up on the dash, but nothing changes on the actual lights.
It's apparently been like this since I got it, and I assumed it was normal until I thought about how bright that light looks. People flashed their high beams at me at night from time to time, but I thought that was due to how bright the xenons seemed.
Taking it over to the shop right now.
