Dunno what I did
2009 S550 AMG sport pckg. 2014 Ford F-150 Lariat Supercrewcab
Dunno what I did
hey I need alittle help. I was fooling around with the settings on my 03 e320 the other day and i thought I would see if I could check out what items needed to be serviced for the next maintenance. I remember reading a post that showed how to do that. I had the key in position II and toggled the display to show the temp. next i toggled that to the FSS screen and it showed the amount of miles to my next maintenace. next i pressed the R button for between 3or 5 seconds and it went to a screen that said
item data
service data
special work
and I forgot what the last menu said. anyway i went fiddling through the menus and none of them showed what items needed to be done so i exited back to the FSS screen but it said "service display not possible" instead of displaying the miles till the next maintenance interval. WTF did I do?? my last maintenance was like two weeks ago so if i reset it it prolly won't make a difference but does anybody maybe know what i did so i possibly don;t have to reset it???
item data
service data
special work
never mind it went back to showing the correct mileage when I turned it off and left it for a few minutes. Just wonder if I screwed any settings up
03 E500 and Corvette
Originally Posted by jangy
Try the ECU reset and see if it clears it up. if not, just tell the dealer to deal with it and say you don't know what the hell happenned.
So if I were you I would look again at the service but DON"T press confirm on the CONFIRM All. That is the button I accidently pressed. I think had I just confirmed 1 item such as oil change it would have been a non issue.
Ok so I but at least you know you aren't the only one looking at "what is your service" prior to paying out $$. Jim
