Tire Hydroplaning
The MXV4's are ranked 10th out of 16 (6.4 out of 10) on Tire Rack's user survey for hydroplaning resistance (MXV4+ is ranked 8th at 6.7). http://www.tirerack.com/tires/survey...ll&sortValue=3
I run Goodyear Eagle F1 GS-D3 summer Z-rated performance tires on my car, and they are excellent in the wet (#2 per Tire Rack's survey, 8.9 out of 10). http://www.tirerack.com/tires/survey...ll&sortValue=3
I realize that the "ratings" are subjective rankings, but they are a good guide to look at when selecting tires.
Lou
Lou
I agree 100% Goodyear Eagle F1 GS-D3 are amazing in Wet or Dry. They are by far my fav choice for tires.
3 questions.
How many miles on the tires?
How much tread depth do you have?
How fast where you going?
Just my 02 cents
Stevec32
Just my 02 cents
Stevec32
"Hydroplanning is not any speed over the formula result but within approx 5 MPH on either side of that number. ""
So are you suggesting you need only exceed 5 mph over the hydroplaning speed and you will avoid it?
If so you need to tell NASA right away. Because they have it wrong
)I think it is time to change your tyre brand. You sure you were hydroplaning at such low speeds? the E class is a pretty heavy car....i'm very surprise your having problems at such low speeds with it
Perhaps you were a bit paranoid ? and felt steering feedback on the wheel ? Was it pulling the front end to the left/right ?--under rainy conditions you shouldnt counter steer to fast.. just follow the front end and then pull carefully to wherever u want to steer the car.
The MXV 4 starts out with 10/32 inch tread depth (8 mm). At 15k miles, the tires may be already 50% worn (4 mm). You can get an inexpensive tread depth gauge to verify my hypothesis.
The difference between you and that older S class may have been that your vehicle has ESP (stability control) and that older S class may not.
Have already made most of my tropical storm preparations so I had time to play online.
