AM radio interference when brakes applied?
I know... I know... "what's AM"...
Had the oddest intermittent thing happen on the highway the other day, in stop and go traffic; we'd get serious signal interference when using the brakes!
Anyone out there ever had this happen, and what might the cure be?
Thanx in advance!
Murman
Thanx in advance!
Murman
1 Post
2006 E350
Had that problem with an older vehicle I had with an antenna that has been stuck and would not rise. Don't have a solution but it may be just a faulty antenna or electrical interferance.
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Could be a bad antenna amp, bad connection or a bad ground on the SBC system. The latter could create a big problem. Have you had the bulletin done on it??
Received 4,435 Likes
'71 Pinto
https://mbworld.org/forums/e-class-w211/147614-radio-problems-05-cdi.html
