oil change questions
2, Oil Type in manual shows 05 to use CG rated oil. Does Napa or Walmart carry?
Perhaps Konigstiger has information that I don't. He tends to know everything and is the most indispensible member of this forum, IMHO!
Does this make sense? Anyway, I really don’t think that there is much of a difference between a 0-40 and a 5-40.
Steve
Steve
I got my oil tested again. It had about 5,000 miles on it, the car had about 16,000 miles and it was the second oil change that was originally changed at about 10K. All the break in debris were gone, the TBN was much higher than at the first oil change at 5k miles. The oil was in perfect condition and the lab said I should just go with what the computer says now since the engine is totally free of junk from break in.
I will try and post the result in the service thread. I will have the oil changed, free of charge, when the life of this oil only hits about 5,500 miles because the FSS computer will say so, but this change will be the first one that I will run about 10k miles on and maybe test it after that. I have not been resetting the FSS computer when I had the oil changed between service requirements. No point in throwing away perfectly good oil though, so I am beginning to trust MB’s FSS.
Steve
