E-Class (W211) 2003-2009
Will these fit...
Old Oct 1, 2006 | 05:50 AM
CombatBenz's Avatar
Will these fit...
http://cgi.ebay.com/ebaymotors/20-Br...spagenameZWDVW
let me know if these will fit my car.. 06 W211 E350 sports HnR springs
Old Oct 1, 2006 | 02:18 PM
tbone's Avatar
E500 Sport
Offset should work, but the front offset may be too conservative. Your rim may not be as flush with the fender as you'd like. You may also end up rubbing on your inner side with this offset and that tire size. The tire's a bit tall. Proper tire size for a 20" rim is 245/30/20 and 285/25/20.
Old Oct 1, 2006 | 03:44 PM
lkchris's Avatar
'10 CL550, '12 GL550
You need to verify that 14mm lug bolts are usable with these wheels.
Earlier E-classes, etc. used 12mm lug bolts ... which won't fit your hubs.
