Urgent Help Pls (SBC)
currently, my 211 show a red warning lamp display "Brake Failure Visit Workshop". After diagnose the vehicle, the fault was pressure accumulator sensor faulty.
Can any1 tell me what is this Pressure Accumulator Sensor and it's location.
Also what is the procedure to bleed the SBC system?
All help would be greatly appreciated.
Thank you in advance.
mike
Take it to the dealer.
Also, it's safe to change pad/rotors if you know what you are doing but I sure wouldn't try to bleed the brakes. Early on, many SBC failures were due to dealers doing it incorrectly.
As a matter of reference, SBC must be bled after the replacement or removal/installation of the following components: Hydraulic Unit, Brake Operating Unit, Suction Line, Pressure Reservoir, Brake Lines, Brake Fluid Reservoir, Brake Hoses, or Brake Calipers.
If you want a copy of the extended warranty details and/or SBC bleeding procedure forward your email address by PM.
