E-Class (W211) 2003-2009
2003 E-Class oil leaks?
Old Oct 24, 2006 | 11:08 PM
myblackSL500-2001's Avatar
I have been told by some MB owners that the 2003 E-Series has a problem with oil leaks. Is this true or just a bad rumor of a few? There are many 2003 E320's and E500's at dealers that are Certified. Let me know before I buy.
Thanks.
Old Oct 25, 2006 | 12:08 AM
mbuskuhl's Avatar
sold - w211 e320, f250, rx7 race car
Hadn't heard of that one before. I've got an 03 and no major complaints, then again it only has 26k miles on it.
Old Oct 25, 2006 | 12:44 AM
DWP's Avatar
DWP
'08 AM Vantage V8 - '03 E500
Our '03 has been parked overnight in the same spot in our garage, with nothing but bare concrete beneath it, for over three years. So far as I can see it hasn't leaked a single drop of oil or other fluid in that time. Only 27,000 miles on it, though.
Historical side note: Our garage was built in 1937 and it's apparent, from the pattern of ancient oil leaks on the concrete (heavy splotch in front, smaller splotch in the rear, long connecting splotch for the driveshaft) that cars used to routinely leak a lot of oil. Tolerances seem to have tightened a lot in recent decades.
Old Oct 25, 2006 | 01:04 AM
rickyfanmdr's Avatar
2003 E320
No oil leaks here either.
Old Oct 25, 2006 | 01:05 AM
2003 E320
Old Oct 25, 2006 | 02:27 AM
Firenza's Avatar
E350
Not a tiny single drop of oil leak after 92000km (57k miles).
Old Oct 26, 2006 | 02:02 PM
sinocomp's Avatar
03 E500 Sport
I have a 03 E500, but I have oil leaking problem last 4 months. originaly I didn't notice , one day when my wife drive the car out , I found the 4 inch spot of engine oil, then I go under , and find the it may be the oil pan, so I took it to Benz dealer, car stay there for 4 days for parts, and back, after few days, new fresh oil drop again, I took it back again,,
total 4 times back and forth, they keep redo anything related to oil pan, both upper level and lower level. the the 5th time, they change a "dip stick seal" , after that , no more leaking , and the car run very smooth.. I think it is because they change engine oil everytime , the oil now is like clear green water :-) ,, very clean,,,,
I went online and find what is dip stick seal.. .. it just 2 rings ..? I still don't know what is this, but it works..
other than that,, no problem at alll...........
ps. if someone know what is dip stick seal,, share with me.. :0
Phil
Old Oct 26, 2006 | 02:04 PM
sinocomp's Avatar
03 E500 Sport
add to my prev post, my car is now 37450 miles...
Old Oct 26, 2006 | 02:43 PM
SAguirre's Avatar
04 E320 4 Matic, 95 Audi S6, 99 Carrera 4 Cabrio, 12 Fiat 500 Sport, 00 BMW R1200C 10, BMW R1200R
Phil
The dip-stick seal is a ring seal that goes between the tube (that guides the oil dip stick into the oil pan) and the oil pan. This is a very cheap part and if it does leak, it would leak around the oil pan and make it look as if the oil pan seals are leaking. It is such a simple issue that it is often overlooked and causes mechanics to start working on much more complicated items that could be the cause.
You should look at this as if you got a really good engine oil flush! I seriously doubt that this will happen again and is quite rare.
Steve
BTW, I have never had an oil leak on any of my Mercedes cars. Knock on wood!
Old Oct 26, 2006 | 03:24 PM
Benz-O-Rama's Avatar
I don't even think my car has a dipstick. Must check oil level through the MFD
Old Oct 26, 2006 | 03:35 PM
paulv's Avatar
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
B-O-R,
You're right -- we don't have dipsticks, and the tube is for siphoning the oil for an oil change (as most dealers do). There is a dipstick that dealers use in case the digital sensor fails -- you can buy one of these from a couple of tool shops, but it's not made to leave in the tube.
BTW, the only oil leaks I've ever heard of people saying were from the level sensor or the tube seal as previously identifed by Steve.
Regards,
paul....
Old Oct 26, 2006 | 03:38 PM
loudbmw's Avatar
17 E300, 17 C300, 14 C250
My former '97 E320 (straight six engine) leaked badly after 100K miles. The straight sixes back then had head gaskets that failed. My former '99 E430 (V8) never dripped a single drop after six years.
My current '05 C320 (V6) is still tight after 18 months as is my year old '06 E350 (V6).
Me thinks the oil leak problem from the straight sixes dropped dramatically with the introduction of the V6.
Lou
Old Oct 26, 2006 | 03:41 PM
paulv's Avatar
Oil sensor leak TSB
Here's the link to the TSB that talks about the oil sensor leak
http://www.alldata.com/tsb/Mercedes-...0-29A/291.html
Regards,
Paul...
Old Oct 26, 2006 | 05:08 PM
SAguirre's Avatar
Like stated after my post, the tube is there, but there is no stick that stays there. I don't know if the newer models now have a dipstick. One reason you would not think that there is one is that the regular RWD engines/power trains have the dipstick between the back of the engine and the firewall. 4-Matics have it in a very visible and convenient location. I posted a picture of mine some time ago but I cannot find the thread now.
Steve
Old Oct 26, 2006 | 10:01 PM
Reckdriver's Avatar
2003 E500
It seems I'm in the minority, but to answer your
question, YES. I had the car (2003 CPO E500) 29 days, yes DAYS with 29,500 miles on it. It developed a massive oil leak from the passenger side valve covers onto the exhaust manifolds. Let me say that I bought this car for fit, finish, luxury, power, and prestige, and I had NONE of those as I sat at stoplight off of the highway with smoke pouring from the hood. I looked over at the guy in the Accord next to me (probably about a 1995 or so with who-knows-how-many-miles on it) and his look was not "wow, great car" but "uh, dude, your expensive and unreliable car is smoking."
The good news is that the dealer fixed it for free under the MBUSA warranty. The bad news is that the work order said something about "valve cover missing groove seating lower to upper valve cover, nec to R&R lower and upper valve cover". I still don't know exactly what that means, but I wrote a letter to the dealer to which he has responded with a voicemail. This is a coincedence in timing that I read your post tonight, but I am calling him back tomorrow.
All that said, don't get me wrong. I LOVE the car. MB has styling and power that is, well, uncomparable.
I'll report back with what the dealer wants to do about my oil leaking issue.
Mike
Old Oct 27, 2006 | 05:57 PM
Double Eagle's Avatar
2003 E-500
Regards,
Paul...
I had the oil sensor leak in my E-500 in January 2004. Then they replaced the sensor, did an undercarriage wash and threw in a free detail for my trouble. No problems since.
Old Oct 28, 2006 | 02:11 PM
E500wanabe's Avatar
07' E350 sport
Phil
You car is probably still under warranty but any idea how much it cost to reseal the oil pan or how easy it would be to do.
Chris
Old Oct 29, 2006 | 07:30 AM
Randy B's Avatar
**SOLD***2003 E500
Rear main seal leak
I've got a a very small rear main seal leak. Not enough to drip out of the underneath fairing, however when you remove the fairing you see it. Dealer quoted me $375.00 to change it with labor.
My front thrust arms bushings had leaked and is apparently common. Replaced those when I did the lower ball joints.
That's all as far as oil leaks go.
Randy B
Old Oct 29, 2006 | 08:13 AM
sinocomp's Avatar
03 E500 Sport
It shows Parts for 52.15 , mechanical labor is 650.10 , total 702.25 on the first bill , and you are right. ... warranty paid it. :-)
Chris
Old Dec 15, 2007 | 03:10 PM
Tariq's Avatar
S500 W223 2021
I was searchng for thread in regarding oil leaks..
I have 2003 E500 , and notice since a week an oil leaks , it spots arround three times in every 6 houres car stop.
Dont know if any one had the problem and how do you fix it.
i wish to know the couses..
Regards
Old Dec 15, 2007 | 10:01 PM
georgedaman's Avatar
GL350
108k... not a drop
Old Dec 16, 2007 | 09:33 AM
vettdvr's Avatar
03 E500 and Corvette
Regards
Our E500 has 72,000 miles and doesn't leak. After 1 service it did drip and used 1 qt of oil between service. I suspect the plug wasn't tight because after the next service there was no leakage and the oil consumption went back to normal.
