Obsidian Black
What you should do is go to the dealer and look for yourself. Both colors have been around a long time and you should have no trouble finding several cars in each (particularly if you stroll through their used lot).
I have obsidian black and you have to see it to visualize the difference.
If there's no direct sun, the obs and flat blacks look virtually the same. In sunlight, the obs is metallic black. It's 'blackness' is not much different than flat black unless it's viewed in very good light.
Here is one of pic of mine, you can't tell by pictures, but Obsidian black really shines under the sun, the metallic shows pretty nice, I like it better than true black because of the metalic shine (I know I kind of said the same 2 times
Wow...this is good stuff. It will definitely make others notice your presence. How is the reflection like on a sunny day towards other road users?
do u use wax, or zaino? by the way, good job on hitting 2000
Thanks on the 2000 hit!
"_____ Was here" on your hood.
