E-Class (W211) 2003-2009
Srs Malfunction!!
Old Dec 3, 2006 | 04:34 AM
fusion2007's Avatar
CLS 63 S AMG , s500,clk550
Srs Malfunction!!
hi everyone i was wondering how to reset the srs malfunction light. i keep getting the message on my cluster. wat are the codes on the nav system to get into the command and reset it. thanx
Old Dec 3, 2006 | 03:00 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
SRS malfunction should not be reset. It shows that the airbag system has a problem. This should be addressed by the dealer ASAP.
Re the Command system, exactly what do you wish to reset??
Old Dec 3, 2006 | 10:53 PM
mbtech360's Avatar
Srs
Even if you do reset it, it will just come back. Chances are its a occupancy sensor that needs to be recalibrated...or a wire harness update for the steering column module.
Old Dec 9, 2006 | 11:53 PM
fusion2007's Avatar
whats the code to get into the system to reset the srs. will the code still work if i dont have the navgation command?
Old Dec 10, 2006 | 09:24 AM
SUNILP's Avatar
2015 E250D
there is no code to reset the SRS system.
Old Dec 10, 2006 | 10:57 AM
sosh's Avatar
As stated you cannot reset this and it must be done by a dealer with the Star system. However you do not seem to understand the implications of this warning. It is a very important safety warning and indicates that your safety system will not operate. The warning is very important. Do not believe a dealer will even attempt to reset it without the correct repair. Even if they do it will immediatly return. GET IT FIXED!!
Old Dec 10, 2006 | 01:59 PM
fusion2007's Avatar
im pretty sure its not really defective. its just a bad sensor that needs to be replaced or reset.
Old Dec 10, 2006 | 02:40 PM
sosh's Avatar
You are being stubborn and dumb. If it needs a sensor its defective, if the light is on its defective, it can't be reset!! Its a serious safety issue. How on earth do you know its not?? Do you have ESP?? Keep up that kind of thinking and you will end up where you do not want to be. If the rest of your vehicle is maintained like this problem you are not going to have anything left of it is a short period of time.
Old Dec 10, 2006 | 06:31 PM
fusion2007's Avatar
haha true!! ill get it looked at.. thanx
