E-Class (W211) 2003-2009
interior part question
Old Dec 5, 2006 | 07:57 PM
ilm's Avatar
ilm
2004 E320 / 2007 SL550 / 2008 GL450
Does anyone know how I can find out a part number for interior molding? I need to replace the molding (covered in fabric) on the driver side just below the roof. I got INK on it.
Attached is a picture of the piece - only I need it for the driver sdie.
Thanks!
Old Dec 5, 2006 | 08:59 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Your dealer should have that information readily available at the parts department
Old Dec 5, 2006 | 09:34 PM
MB Fanatic's Avatar
4 wheels
A pillar trim piece. Take your VIN to your dealer and they will get it for you.
Old Dec 5, 2006 | 11:12 PM
ilm's Avatar
ilm
Thank you - my car is going in for state inspection next week....we make a stop over at the parts dept. I was just hoping to order over the web and save some $$
Old Dec 5, 2006 | 11:15 PM
Barry45RPM's Avatar
2015 ML 350
If its Sharpie ink, denatured alcohol will remove it. Ball point can be removed with brake fluid.... but I would try VM&P Naphtha 1st. (Dab, don't scrub.) What have you got to lose?
You might also consider checking a junk yard for the part. Maybe a car was totalled due to a side or rear hit.
Old Dec 6, 2006 | 10:10 AM
ilm's Avatar
ilm
I tried alcohol - with no luck. It got to the point where the fabric started to come off....so I actually made it worse. UGH!!
Old Dec 6, 2006 | 10:20 AM
TPAbnz's Avatar
2017 E300W
Barry's giving you the best advice. It should pull the ink. Naptha is sold in paint stores.
Commonly sold as Energine, this also does a great job on removing sticker glue (ie sunvisor warning stickers).
Good luck.
