Static with Euro Comand and Navigation module
Any ideas
Basically it suggests the paint on the frame of the AGW and on the plate at which the frame is attached to the vehicle’s body may be acting as an insulator. Unplug the AGW voltage supply and ground. Using a multimeter, measure the resistance between the AGW’s housing and the vehicle’s body ground which must be 0. If not, remove the AGW and remove the paint from the surface where the frame from AGW is attached. If resistance still measures more than 0, a Zinc coated AGW bracket (part # A211 545 87 40) is available.
I'm sure if you need a more technical description of the process, Kongstiger should be able to provide it.
All kidding aside, that was a great POST!!!!
Randy B
