AMG staggered wheels on 4matic? what offset? who has done it?
is staggered not recommended because of the 4matic sensors? I am thinking of using 245/40/18 8.5 front / 275/35/18 on the rear .. this will give me about 11mm diff in circumference (2052.1mm and 2041.1) (326.6 mm radius and 324.8) .... note that different tires are slightly + or - vary by manufacture.
the E65 comes with 8x18 ET 30 245/40/18 9x18 ET 39 265/35/18
the special addition option is 8.5 and 9.5 (see the AMG catalogue)
would the be offsets be diff on a 4matic vs a non 4 or vs an AMG55/65 wagon/sedan?
thoughts, ideas, and cold hard facts welcome.....
thnks
Besides, why would you want to give up the ability to rotate your tires, and get 1/3 more life out of them? The performance gained by having staggered wheels isn't worth the tire life trade off. A passer by won't notice the staggered set up either... I'd just as soon have all four the same on my incoming car. These cars really aren't race cars... its all just marketing.
)my real question is if other than the size of brake rotors.. would the axle dimensions be different from a 4matic and the standard car (AMG or not).. I'm sure that the front assembly is definitely different...but can't imagine the rear axle being different.
AMG wheel package is 8.5/18/ET 38 245/40/18 all around (code791)
Barry,
for me.. it is two fold
1. 18 inch wheels will give a crisper feel while driving.
2. it looks cooler.... I am not looking for a baby hauler... my 05 sport package E500 wagon is a compromise for two cars as I live in the city.. It will take my dog, girlfriend, and any future additions quite nicely... so if I can make it look anything closer to a E63 wagon.. then I will. Let's face it.. if your heart doesn't pound a little faster when you see a E55/E63 wagon...then you need to pump up your Geritol dose...
so back to my question... has anyone successfully installed AMG wheels on a 4matic? what offsets?
...and The E 63/E55 are superb cars but don't even belong in NYC/Long Island, due to the crappy roads, 5 million stop signs, and income producing Radar traps. (I think the entire Borough of Staten Island's budget is funded by traffic stops alone, and everyone on Staten Island IS a Cop or lives with/is married to/or is the kid of a Cop. LOL
Of course I'd like to own one, but paying that much to sit in an identical looking car to an E 350 with Sports/AMG packages/effects, and never get to experience the driving thrill of one, leaves me in an E500, watching my wheels, and looking for who is lurking behind a Stop Sign.
I myself would rather my car came with 17's that looked as nice as the 18 Sport Pkg wheels, all the same size for those reasons. ...but thats why we're all different!
so far.. from reading the AMG download PDF.. I believe that these wheel sizes will work on the 4matic (unless I am corrected..thus this open forum)
8 (8.5) x 18 ET30 (offset) 245/40
8.5 x18 ET38 (offset) 245/40
9 x18 ET39 (offset) 245/40 (rear only)
question... can anyone explain the diff it would be from a 30 offset to 38?
Same reason you don't mount different size wheel/tire rolling diameter wheels/tires on left and right side of same axle.
There's a front/rear differential on 4WDs in addition to left/right differentials.
Just like the fact in a turn the outside wheel is going farther than the inside wheel, the front and rear wheels aren't in the same track and are therefore not necessarily going same speed either.
in or out? how off center does it make the wheel to the alignment that the suspension is designed to be otherwise known as camber? ... c’mon.. anyone with some intelligent answers other than internet desktop experts throwing out advice that they picked up reading a crutchfield catalogue?
(see... another example of a desktop expert)
Kent was also referring to the diameter of the wheels, not the width (if I read correctly).
why may I ask.. if you match the the revs / mile as close as possible
using the http://www.miata.net/garage/tirecalc.html .. that it not work?
I can match 245/40/18 (784 revs/mi) with a 275/35/18 (788 revs/mi) ..would the 4 revolutions per mile be a problem? the width of the tires should not make a difference in my humble opinion.
I was thinking 8.5 front and 9 or 9.5 diff
The easiest way I'd guess is to go to your local MB dealer, tell the SA of your situation, pop a guy $20 and have a rear set of wheels and tires from a sport package W211 testfitted on your wagon. Before anyone freaks out here, you're not roadtesting your car with the wheels, just testfitting them.
the added stress of staggered wheels is usually not great for your 4matic system.
Also keep in mind your ESP will be somewhat thrown off in unequal amounts with a staggered set up
thnks
When you have an ALL WHEEL DRIVE car the ESP works differently that the two wheel cars, All 4 wheels must turn a precisely the same speed. When you use staggered wheels, there is going to be a difference in overall wheel diameter between the front and back. SO, my guess is you will have ESP warnings all the time.
Be AWARE.. since the Factory Doesn't Support this Set-up by design,
you will get laughed at when you drive up to the dealer with Tranny, ESP, or Tire wear issues on warranty and they see you have been running staggered wheels on an all wheel drive car.
I'd venture to say that any MB CSR who says "it should be okay" to do this knowing fully well that you can't even get a car from MB like this should be working the beverage stand not handling service.
But it's your car, and I wish you the best of luck.
The RWD sport package cars have the same ESP system and have a 0.4" diameter difference between the front and rear tires. If he goes with a 245/40and 275/35 staggered setup, the difference between the two in diameter would only be 0.15" which should be negligible. In fact, I bet you can find a difference like that on most 4matic cars now, due to inflation differences or uneven tire wear between the axles. On all AWD cars there's always a certain amount of play allowed between the axles, but I don't know how much it is on these cars.
ESP doesn't know anything about the width of the wheels and tires, it only measures the differences in speed between the axles, which would be sensitive only to the diameter of the tires.
As I see it, the main issue would be the width of the tires, and if there's enough clearance to mount them or not.
the real issue for me is going to be offset. (cause if I am buying aftermarket or from non MB sources or they are take offs from another car...so I won't be able to send them back!)
RWD, kicks in on Rear wheels... it may apply brakes to front wheels but it cant transmit power...
when the equations are calculated they are coded for certain ratios... SO by putting in staggered wheels... you throw everything entirely off...
This is exactly the same scenario as the new Jeep Grand Cherokee SRT8. They come with a staggered setup from the factory, and the AWD system on that car functions the same as 4matic. The power is sent to the rear wheels until there's a difference in speeds, then the front axle kicks in. That car arrives from the factory with staggered wheels and tires, but they are the same diameter all around.
Trust me on the Jeep issue, I was seriously looking into one before getting the E. I'm just not sure if there are any differences between the Jeep's system and 4matic.
Any awd car could run a staggered set up or even different size rims, if its designed to, the E class was designed to run equal diameter and equal width, mechanically it COULD be possible, but electronically, the amount of force its calculating on the rear wheels is going to make it think that the front wheels are lacking traction(smaller width, less contact area, less traction) hence on a normal turn, your going to see a blinking orange triangle on your dashboard
The SRT8 uses a dumb down version of our ESP... I believe version 1 type of thing while our cars are on a much more advanced system...
this is part of the technology sharing with Chrysler, they get older technology from MB...
