E-Class (W211) 2003-2009
glove box problem
Old Mar 6, 2007 | 01:44 AM
mspaul's Avatar
2018 Macan, 2018 Panamera Turbo S E-Hybrid, 2024 G63
glove box problem
Glove box in my 03 e320 when opened falls freely... shouldn't it be opening slowly.
I mean, You open the glove box and it bangs down. Is this the way it works?
Old Mar 6, 2007 | 02:41 AM
raymond g-'s Avatar
99 E320
i believe this is the cause:
attached to the glove box's exterior (inside dash) is a plastic piston. this
is attached to the door via somewhat flimsy plastic, lattice like webbing.
it is flexible and if the door is forcefully pulled open, the webbing is the
part which gives way.
if you pop the glove box out (which is quite easy....to access cabin filters),
you may be lucky and see that the webbing is easily rethreaded to the piston.
if so, you're back in business. if not, just replace the webbing with anything
which is flexible and will fit the door-to-piston connection.
the glovebox for the W210 takes about 3 mins slow, to remove
....the gray goober you see is my JBWeld fix
Old Mar 6, 2007 | 01:12 PM
mspaul's Avatar
Thanks Raymond
I'll give it a try (Hopefully today).
You guys are great!!
If you Own a MB, this is the place to be.
Old Mar 6, 2007 | 02:40 PM
TPAbnz's Avatar
2017 E300W
My dealer fix for that problem was to replace the glovebox and door - warranty item.
Old Mar 7, 2007 | 02:51 PM
mspaul's Avatar
Do I have to un-screw something to make the glove box pop out.
I did give it a try but am afraid of breaking something.
Will appreciate any kind of help.
Old Mar 7, 2007 | 03:36 PM
raymond g-'s Avatar
99 E320
http://tinyurl.com/23hdzj
http://video.tinypic.com/player.php?v=455m91w
this video shows how to remove the dash trim....but!....it has 10 second
inclusion of how to remove W210 glove box.
Old Mar 9, 2007 | 03:58 PM
mspaul's Avatar
What about W211, How different is it to pop glove box out in W211?
Any Video available for W211?
Old Mar 12, 2007 | 12:15 AM
raymond g-'s Avatar
99 E320
http://www.mercedestechstore.com/w211.htm
yes, it'll cost you...unless someone already owns that and feels compelled to
post a similar clip. did you try searching the forum? if your filters are behind
the glove box, it's unlikely that you're the first to ask about glove box removal.
