Changing Airfilters
I figured that it wouldn't be all that hard.. the car is new to me (less than a month)..
so I started to figure something was wrong when I saw how small the A-filter was when it showed up! (Green) ... DUH!
I need two of them! So as I am standing to the side of East 52nd street here in NYC.. (temp 18 degrees) ... looking under the hood figuring it would be an easy swap.. got the baffle tube off ..and the front part of the plastic cover... and that is as far as I got!any help would be appreciated!
Make sure you relaese both baffle tubes up front and remove the small plastic piece up front around the oil filter. After that grab the back of the large plastic cover with both hands spread approximately 18 inches apart and pull upwards. After they release lift from the front in the same fashion and the cover is off.
Make sure when you go to re-install you hit the rubber mushroom headson the engine with the pressure clamps on the cover. If you mis-align you can crush the pressure clamps and the cover will not go back on so nicely.
Randy B
if u need help im in BK if you wanna drive over
are you part of the NYC MB crowd? do you know sleeperx (Frank)? great guy... just bought some PS2s off of him last night for my new CLS wheels.
dhp
