E-Class (W211) 2003-2009
06 E500 AC help
Old Mar 10, 2007 | 12:22 PM
TRUKWORX's Avatar
2006 E500 sport,04 Silverado Duramax
06 E500 AC help
I have a 06 E500 sport That was hit light in the front right,It still ran and drove, I replaced the ac condenser and tried to charge the system but the compressor will not come on, it held vacume fine,does anybody know if the air bag module would have anything to do with this..Thanks
Old Mar 10, 2007 | 01:53 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Inspect the LOW Pressure switch...That turns the A/C compressor on when a charge is detected and Will SHUT OFF the Compressor when its low on a charge...Inspect the wires and the connector ...
Tempory repair is to bridge the connector and then charge the system..Do NOT Overcharge the system! its listed on a decal on the amount to charge
Old Mar 10, 2007 | 02:20 PM
TRUKWORX's Avatar
Ac
I checked that first,it looks fine, I was going to jump it but it has 3 wires,where as most cars have two,I have looked all through the owners manual for AC fuses and relays=not much luck,Thanks Mark
