E-Class (W211) 2003-2009
2004 E500 Ipod connection kit
Old May 13, 2007 | 05:00 AM
martialp's Avatar
2004 E500
HI I have a 2004 E500 and was told by the local dealer that I cant connect my ipod to the Merc system. Any help would be greatly appriciated.
Thank you
Martial
Old May 13, 2007 | 07:26 AM
Scambo's Avatar
'13 E550 W4
I connect mine through the AUX jack located inside the glove compartment. Works like a charm. Get yourself a good cable to connect, not one of those cheap ones. It will help you get better connectivity. The glove compartment is kept closed once you plug in, with only the cable hanging out. When I exit the vehicle, I take the iPod with me.
Old May 15, 2007 | 06:29 AM
martialp's Avatar
2004 E500
Thank you very much.
Martial
Old May 15, 2007 | 01:49 PM
rhodesdad's Avatar
2003 E500, Sport, Nav, Pano, HK
Smile
I have a 2003 E500 with the 2004 electronics--COMAND with NAV and HK sound system--one of the "replacement cars" for the US market. The IPOD kit works just fine in it. Dealer said it would not work, but it does. Shows tunes, etc in MFD. Controls for the IPOD are in the steering column. You lose the AUX input and the IPOD gets wired in the glove box. No problem. Great solution. A little expensive, but works great.
Old Jun 8, 2007 | 09:45 PM
no_clue's Avatar
.... nothing to brag about, it is a previous model....
Thank you
Martial
You can if you get the fiber optic ipod integration kit.
About little over $200 from dealer. So you can control ipod from your steerling wheel etc.
ebay might have for little cheaper.
http://cgi.ebay.com/MERCEDES-BENZ-I-...QQcmdZViewItem
Old Jun 8, 2007 | 10:30 PM
SUNILP's Avatar
2015 E250D
ipod kits can be integrated on any usa w211 2004 and later. It works fine and the cable has to be routed to the rear Audio gateway which makes installation a pain.
