E-Class (W211) 2003-2009
W211 Newbee question
Old May 29, 2007 | 10:18 PM
Tank7's Avatar
2017 GLC 300 Coupe'
My E320 CDI does something unusual when I back out of the driveway. I back out slowly but there is this thud as it goes off the driveway on to the street. Like I was in a Soprano's episode and there was a body bouncing around back there.
I checked the spare and the tool kits. All are secure. I velcro'd the trunk mat down so it would not slide so it can not be that either. I also looked at the battery and I can not see anything loose.
Any ideas? Could it be 20+ gallons of diesel sloshing around?
TIA
Old May 29, 2007 | 10:35 PM
Benz-O-Rama's Avatar
TIA
Is your car equipped with the airmatic suspension? If so, read this:
https://mbworld.org/forums/showthrea...ight=dead+body
If it doesn't have the airmatic, then I have no idea.
Old May 29, 2007 | 10:49 PM
Tank7's Avatar
2017 GLC 300 Coupe'
It does not have the airmatic. But sounds like a lot of people have experienced it. Will have the dealer look at it. I have 3 year CPO if it is the rear suspension I hope to heck it is covered.
Old May 30, 2007 | 06:08 PM
georgedaman's Avatar
GL350
TIA
Shocks
Old Jun 1, 2007 | 06:32 PM
Tank7's Avatar
2017 GLC 300 Coupe'
Originally Posted by georgedaman
Shocks
Yep, looks like you are correct. Took it in and service manager drove it. Said at least on of the rear shocks needs replacing if not both. Will go in next week for surgery.
Thank you and thank g-d for the extended cpo
Old Jun 1, 2007 | 09:45 PM
GL350
No problem.
Old Jun 9, 2007 | 12:01 AM
Tank7's Avatar
2017 GLC 300 Coupe'
Shocks
Well they replaced the shocks yesterday and it did not remove the noise. What it did was make the noise more interesting or for lack of a better description, more defined. Now as I reverse, and slowly brake the noise seems to coincide with the braking but after a very small delay. Like the brake calipers are clamping down? Or could it be something in the drive line like a u-joint?
Weird
Old Jun 9, 2007 | 12:07 AM
konigstiger's Avatar
'71 Pinto
My guess would have been the shocks also. Anyway, schedule another appointment and specifically request a road test with the shop foreman and attempt to duplicate the noise heard.
Old Jun 17, 2007 | 12:14 AM
ko123an's Avatar
It could be the bushing. I had the similar problem everytime I went over a speedbump. Took it in and replaced the bushing. No more thuds.
Old Jun 17, 2007 | 10:23 AM
Tank7's Avatar
2017 GLC 300 Coupe'
Do you know exactly which bushing? I would imagine there are several.
TIA
Old Jun 17, 2007 | 01:01 PM
ko123an's Avatar
TIA
That I do not know. The mechanic seemed to know which one it was
