Question Re: Xenon Headlights
Are Bi-Xenon Headlights / Xenon Headlights standard on the 2003 W211?
If not, is there a way to differentiate them simply by looking at them?
Thank you for your help.
-TulaneLaw
-TulaneLaw
'06 E500, '99 ML430 and '07 SL65
Some have bought OEM MB BIX lights and installed them and the only way to really tell is to either take out the bulb, look under the light assembly where the igniter is located or try to switch them on at night and you will see them go bright as they ignite and then dim a little down to where they should be. You can also ask the dealer to hook up the StarDiag computer ask see if the BIX option is set to 'on' in the system.
2007 MB E550 Sport
Maybe this was true with prior years, but not with the current model. I had to special order my E550 with P2 to get xenons.
In which case, it can be used with the rear fog light
man dont i like you i just had my car wash from the dealer as soon as i pull out of the lot there is this one F350 lifted that sprayed his windsheild at 35mph and it splashes all over my cat . im not pissed at all
i just want to kill his ***.
good thing its a free car wash
and besides that hes kind of big
Harley-Davidson
Originally Posted by FormerC32Owner
I don't think that's true in the new model. I always thought that headlight washers and xenons were synonymous, but I learned that they're not. All of the '07s on my dealership's lot were E350s and E550s with P1. All had headlight washers. None had xenons...
