E-Class (W211) 2003-2009
White LED bulbs license plate
Old Jun 24, 2007 | 02:22 AM
jagata's Avatar
S6 LP640 E500
Well was bored and thought I try something simple and different, this is my attempt to make the rear look a little more modern. Is it OK or is it too gay?
Old Jun 24, 2007 | 03:43 AM
rodE350's Avatar
2006 E350
Looks good to me. Where did you get the LED bulbs? I may have to do it to.
Old Jun 24, 2007 | 04:05 AM
j_belll's Avatar
‘23 EQS AMG
yea not too bad. i like it. was it hard to replace?
Old Jun 24, 2007 | 03:14 PM
jagata's Avatar
S6 LP640 E500
The lights you can get at any automotive accessory store, or online. Do a search for "festoon 39mm white led bulbs" you will also need resistors connected otherwise a "bulb out" message will appear on the cluster. It was pretty easy if you need details PM me and i'll go further into it for you.
Old Jun 24, 2007 | 09:28 PM
alewifebp's Avatar
2014 BMW 550i
Look at this thread in the W210 forum: https://mbworld.org/forums/e-class-w210/148800-10-modification-you-all-can-do.html
Many were able to do it, but many also had failures, such as myself. I've been considering going back to stock, even though the look is quite nice. Just not reliable.
Old Jun 24, 2007 | 09:50 PM
Tank7's Avatar
2017 GLC 300 Coupe'
The heck with the bulbs, man what a garage. Tile? TV? Two tone paint job...
Nice digs man.
Old Jun 24, 2007 | 10:10 PM
Benz-O-Rama's Avatar
Actually, it's not horrible. I'm kinda digging it. Nice garage too, but get rid of the tube TV and throw up an LCD or Plasma!
Old Jun 24, 2007 | 10:32 PM
jagata's Avatar
S6 LP640 E500
I'll get a plasma when the old tube goes out, it's one of those funny things when you want something to break but won't and when you need it the most than it breaks. LOL.
Actually I had the bulbs in for a couple of weeks now and seem to be holding up.
Thanks for the nice comments.
Old Jun 25, 2007 | 07:13 AM
emilner's Avatar
S560
I think the plate looks good, but I have to ask about the garage. Are those regular ceramic tiles on the floor? They look awesome, but I would worry about them breaking under the weight of the car, did you have to get a special tile? And yeah it is screaming for a plasma...
Old Jun 25, 2007 | 02:57 PM
jagata's Avatar
S6 LP640 E500
Tiles are regular 16x16 beige tile from Lowe's 1.38 per tile, planed on getting racedeck but they cost more than the ceramics and IMO the ceramics makes my garage look more classy. They will crack by the weight of a vehicle, but the key for them not doing so is apply a even amount of thin set especially the corners. I'm very pleased with the results and keep the garage clean and minimum clutter.
Old Jun 25, 2007 | 06:39 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
I love the LEDs. What resistors did you use? And yes great garage keep the tube TV and get a tool box.
Old Jun 25, 2007 | 08:09 PM
jagata's Avatar
S6 LP640 E500
Nice I see you have them on your e55, I used radio shack 50 ohm 10 watt resistors part #271-133.
Tool box is in front of the car next to the cabinets.
Old Jun 25, 2007 | 11:13 PM
foofighter's Avatar
i wonder if you can use a capacitor like the one used for HID to provide that dummy load in lieu of resistors.
Old Jun 26, 2007 | 01:15 AM
jagata's Avatar
S6 LP640 E500
You maybe able to, but why would you cause the resistors cost $2.00 for a 2pack while most capacitors run around $10.00 each to do the same thing.
Old Jun 26, 2007 | 05:27 AM
pinebaron's Avatar
07 E320 Bluetec
Use for resistor
You cannot use a capacitor instead of a resistor; a capacitor is used to store energy while a resistor is used to resist energy.
A standard 12V vehicle battery is too many volts for an LED; hence using a resistor drops the voltage so the LED does not burn out. Selecting a resistor of the correct wattage is important since it dissipates energy; Resistance (in ohms) X Current (in amps) = Watts dissipated. The attached gif shows 9V but think of it as 12V (I did not have time to edit it).
PineBaron
