Need Torque values for brake job front and rear
I have read on the boards various DIY accounts of oil changes and brake jobs. Does anyone have the needed torque values for both these jobs.
1 Post
2007 A8L 4.2
Oil change:
Oil drain to pan = 10 Nm
Screw cap at oil filter = 25 Nm
Brakes:
Front:
Fixed caliper self locking bolt caliper to knuckle = 115 Nm
Bolt pad wear sensor = 8 Nm
Dust shield locking bolt = 10 Nm
Rear:
Floating caliper guide bolt on caliper support = 28 Nm
Bolt pad contact sensor = 8 Nm
Hope this helps
Brakes:
Front:
Rear:
Hope this helps
I found some more info, for W211.065 post 9-1-03. floating front calipers,
the caliper to guide pins are 27 n/m
the caliper support is 115 n/m
the pad sensor attach bolt is 8 n/m newton / meters
There are different versions depending on bulid date.
