Newbie to E Class can someone help
First of all, the easiest way to find out what came with your car is to have the dealer print out the data card for it. This will list all the things that Mercedes put into your car during the manufacturing proceess. The dealer will need the VIN number of the car to do it.
The Navigation option and the Satellite radio option are part of the P1 or P2 option packages.
If you have Satellite radio, you will have to subscribe to Sirius Radio to activate the service. Go to www.sirius.com for more information.
If the data card shows your car came with the Navigation system, you need to verify that it hasn't been removed. The DVD player is in the trunk on the street side and you open a flap to check for it. If it is there, I would make sure it has the DVD. If not, then I'd ask the seller for it.
Finally, I'd make sure the seller stood behind things. If they told you it had the Nav system, make them produce it and the DVD and get it to work.
Good luck.
what does w and s stand for and what does this switch do... thanks
W or C mode makes it easier to start on slippery surfaces.
