ESP on the dash.....
. asking me what we are going to do. I tried again but this time, I held the key in the start position for like 10sec and then the car started up. However the ESP was still on the dash. I also notice the car did not drive the same. It felt like it was in safe mode or something. the brake and the gas petal was not as sharp at all. we made it close to home and the wife was still hungry. Since it was about 1am its not many options out there, so we stop at CVS. I turn off the car. when we was done. when I start up the car again and I had to hold the key in on again for like 10sec to start.I have an appointment tomorrow to install Sirius, replace my keyless go floor shifter, and to check out my rear power shade. So I have to add the ESP on the list of things the dealer needs to fix...
1. If it was a keyless go start the 1st time, press harder on the brake, sometimes that helps.
2. How are the batteries (2) in the SmartKey?
3. When you have a big malfunction, sometimes it helps to take the key out, open then close the drivers door, wait about 4 minutes for everything to "go to sleep", then try again.
It usually helped for me in my '04.
bc the car was just fine until I pull in the restaurant parking lot and turn off the car and jump out then when I saw the restaurant was closed I was pissed and I jump back in the car turn the key quickly to the start position and thats when the message popped up on the dash. this morning the car started up with no problem, but the car still show 1 malfunction on the dash. anyway I'm getting Sirius installed tomorrow so in the process of they car take a look at that...
Indie only ECU. Any suggestions. Shall I cut my losses and go BMW or Lexus?
