E-Class (W211) 2003-2009
Headlights - How Should They Be Aimed?
Old Aug 26, 2007 | 11:00 PM
jimm's Avatar
‘08 E-350 Sport, C6 Vette & Harley Davidson
I have the fancy Headlights (forget what they’re called) that came with
the P2.
When on bright they seem to point way left. If I’m on a road with trees
on both sides .. it lights up the left tree tops a lot but not the right tree
tops.
I think I read in the manual or someplace that they are supposed to be
pointing “somewhat” to the left. Is that correct? And - if so, how much?
When I take it back for my ESP repair, I will have them checked .. but,
wanted a little “heads up” about how they should be set, prior to going.
jimm
‘08 E350 Sport, P2, Black/black, Parktronic,
Voice, Bluetooth, Burl Walnut, Split rear seat,
Wood/leather steering wheel
Old Aug 27, 2007 | 01:24 AM
Vik888's Avatar
2008 E550, 2012 GL450, 2014 GLK350, 2015 S550, 2020 GLC350e
"fancy Headlights" = Bi-Xenon's
When you say "bright" do you mean "high-beams" ?
Old Aug 27, 2007 | 03:29 PM
lkchris's Avatar
'10 CL550, '12 GL550
Your dealer has specifcations for how they should be aimed and that's how they will and should be set.
Old Aug 27, 2007 | 04:05 PM
NCE500's Avatar
2007 E63, 2006 C55
RE: Headlights
I had a similar problem with my 05, they were not properly aligned when delivered, one illuminated higher than the other by quite a margin. The dealer corrected the problem at the 1st diagnostic service where they used a specific machine to align the headlights. They were perfect after that.
