E-Class (W211) 2003-2009
trick for CDIs, quicker exit out of a corner
Old Aug 29, 2007 | 12:39 AM
seahonu's Avatar
2015 GLK 250 BT
Interesting trick from Mercedes Enthusiast, Feb 07, on getting the most out of the automatic tranny on the twisty backroads & track. The timing of when to use the Touchshift is key. Many of you may have already known this. I didn't... I had been applying this incorrectly as I'm coming OUT of the corner, ie. too late.
"Approaching a corner you simply hold the Touchshift gear lever to the left AS YOU BRAKE, releasing it as you turn in and letting the gearbox select the best gear to exit with. It's quicker and more effective than going down the gears sequentially and means the engine is on boost (> 1600rpms) and ready to give its best as soon as you can see the exit and get on the power, rather than waiting for the turbo to spool up and the gearbox to kickdown."
Old Aug 31, 2007 | 12:05 PM
traumatic's Avatar
Has anyone tried this? Wouldn't holding the shifter to the left just put the transmission into the lowest possible gear (highest revs below redline) and put the diesel engine outside of the torque curve?
Old Aug 31, 2007 | 01:48 PM
Vik888's Avatar
2008 E550, 2012 GL450, 2014 GLK350, 2015 S550, 2020 GLC350e
I've read about this "best gear" feature. Its not just on CDI's but on all the W211's at least 2008's. I've read about it on this forum actually.
