Old transmission software on '07 E550??
They found that I was low on transmission fluid, and needed a SW update. This is a 'paste' of the technician's notes:
"CHECKED AND CORRECTED FLUID LEVEL. PERFORMED ADAPTATION AND FOUND IT DIDN'T FIX 2-1 DOWN SHIFT. CK FOR SOFTWRE AND FOUND OLDER SOFTWARE IN BOTH ME AND ETC. ATTEMPTED TO FLUSH AND SEN CODE BOTH CONTROL UNITS AND FOUND THRANS CONTROL UNIT DIDN'T TAKE THE CODING AND IT WS SHIFTING INTO 1ST GEAR VERY HARD. ATTEMPTED TO RESEN CODE 5 TIMES AND IT FINALLY TOOK AND IT STARTED TO SHIFT SMOOTHLY. TEST DROVE TO VERIFY SHIFTING AND SHIFTED VERY SMOOTH THRU ALL GEARS. FLUSHED ME AND ETC CONTROL UNITS AND PERFORMED ADAPTATION. CLEARED ALL CODES AFTER REPAIR."
If you're having a weird transmission issue, you might want to check for this. It's strange how my '07 ended up with older software....
I also tested driving very slowly - and no jerking anymore.
Its just not the smoothest transmission out there in 1-2 & 2-1 shifts, particularly in winter temperatures, but when I want silky smooth, I drive around in the C mode for month or 2. As a 6 speed, is IS ALWAYS smooth as silk, in any outside temperature and quite luxurious. Its a better 6 speed than a 7 speed & I'm not gonna let any techs update it... been there, done that in the '04 & was never happy with the tranny.
Also DTB P-B-27.00/87b – specific to the 211.022 (e320 Bluetec) and although it actually addresses transmission flare while performing 1-2 and/or upshift in cold condition this CDI control unit software update (Flashware CD 0054488540_001) has been known to solve a number of problems.
