E-Class (W211) 2003-2009
E320 + jackstands?
Old Sep 13, 2007 | 10:23 PM
red97z's Avatar
2008 E350 4matic
E320 + jackstands?
Ok, I won't have wheels for at least a day as I'm waiting for them to come from the company I bought them for, in the mean time, I don't have wheels to put on my car. Is it possible to put my E320 on jackstands until I get them? Shouldn't do any damage to it as long as they're in the right places. Anyone?
Old Sep 13, 2007 | 11:04 PM
mbuskuhl's Avatar
sold - w211 e320, f250, rx7 race car
As long as you have good stands and place them securely, no problem. I had mine on stands for a few days when I blew out two tires and bent the rims.
Old Sep 14, 2007 | 08:30 AM
red97z's Avatar
2008 E350 4matic
Could you tell me where I should place them? I'm used to having a solid rear axle car, this is the first time I'll put jackstands on a MB and IRS car.
Old Sep 14, 2007 | 11:24 AM
Diesel Benz's Avatar
Owner's manual would show the four spots, two at each side, for jacking the car. But you would have to be able to keep the car raised when putting the jack stand, which should be put to the same spot which is used for jacking it up in the first place.
At the front there is a spot in the centre, below the engine, that can be used but I was not able to find a photo showing where it is. Don't remember if there is a similar one at the back.
Old Sep 14, 2007 | 01:58 PM
BudC's Avatar
2011 E550, 2013 GLK
Unfortunately, this is a problem I've run into with my W211's. In the process of cost cutting, Daimler have removed the rubber pads that Mercedes had for years located under the rocker panels. These were used for mounting on jack stands or as spots for lifts to raise the car. These rubber pads were separate from the place where the jack contacted the car.
With the W211's, we're left with a problem in that if you use a jack to raise the car, you can't use that spot for the jack stand.
Apparently, you need a floor jack to work on W211's.
Old Sep 14, 2007 | 06:59 PM
konigstiger's Avatar
'71 Pinto
There was an interesting 4-page article published recently on this very subject, if you want a copy PM your email address.
Bud, yours is already on its way.
Old Sep 14, 2007 | 07:01 PM
lkchris's Avatar
'10 CL550, '12 GL550
There's a nice rubber pad in the center basically under the engine that can be used with a floor jack.
Recent article in MBCA Star suggests that this rubber pad can be used to replace the jack sockets for jackstand use. That is, you go to dealer and buy four of them. Put the jack sockets back, of course, if you then go somewhere.
Old Sep 14, 2007 | 09:09 PM
pinebaron's Avatar
07 E320 Bluetec
I use two floor jacks to rotate tires; no need to mess around with jack stands.
Old Sep 15, 2007 | 01:26 AM
Tom F.'s Avatar
'08 E350, '97 Porsche turbo
Gee whiz. In the old days we would just stack up some bricks on each corner and call it a success.
Old Sep 15, 2007 | 09:34 AM
BudC's Avatar
2011 E550, 2013 GLK
Why Women Live Longer Than Men
Here's how I do it.
Old Sep 15, 2007 | 09:43 AM
emilner's Avatar
S560
Here's how I do it.
You use 2x4's? I usually go with broomsticks...
Old Sep 18, 2007 | 10:57 AM
starbrite's Avatar
2004 E320
This photo taken using a mirror, but shows the center jack point.
Old Jul 20, 2010 | 10:54 PM
AndyBenz's Avatar
E320
Is that a plastic cover that needs to be remove before I can jack the car up?
I'm trying to figure out how to lift the car up a little bit to get to the oil drain bolt.
Thanks.
Old Jul 21, 2010 | 09:10 AM
starbrite's Avatar
2004 E320
No cover to remove, to access that jack pad.
Old Jul 21, 2010 | 12:38 PM
gnma's Avatar
'12 Mustang 5.0, '89 Supra Turbo, C55,
Thanks.
Why not just extract the oil? Research on this forum revealed that there is very little diff. bet. both methods. Plus many dealers extract the oil also. I just did my first DIY Benz oil change and it was so easy and clean!
