Having problem programming the passenger side mirror parking assist position
I follow the instructions in the manual:
1) Turn car on
2) Adjust passenger side mirror to where you can see the rear tire and the curb
3) Hit the memory button
4) Within 3 seconds hit the power mirror down portion of the adjuster
and nothing happens.
Am I missing some secret step?
Thanks in advance,
Rick
1) Turn car on
Thanks in advance,
Rick
.... nothing to brag about, it is a previous model....
1) Turn car on
Thanks in advance,
Rick
1) Turn car on
Thanks in advance,
Rick
What kind of car? year? model? I know the later models dont have it.
1) Turn car on
Thanks in advance,
Rick
1) Turn car on
Thanks in advance,
Rick
I have an '08. I was following the instructions in the owners manual, so I assumed my car had it, seems strange that they wouldn't include such a basic customer convenience item.
I will try to program it with the car in reverse to see if that works.
Thanks,
Rick
2015 ML 350
If you don't have it, set driver 1 & 3 memories to exactly the same position, then lower the mirror while in Driver 3 & re memorize. The only difference is that the mirror will dip down when you press 3 & it will return when you repress 1. Good enough workaround.
Administrator
Check out the help that I received in my earlier discussion on this subject here:
https://mbworld.org/forums/e-class-w211/206698-passenger-mirror-tilt-down-disabled.html
2003 Cl 500
i was having a problem like this till i fixed it on accident. try this, put the car in reverse, lower the mirror to the way you want it, reverse a lil bit, then put the car in park and drive. then test it out, put it in reverse and reverse a lil
ALi
ALi
