Negative Camber!!! Help PLEASE!!
Mercedes does make a camber adjustment bolt for the front and I used them on my car to set the camber correctly due to tire wear. I don't know if it is the same part for the rear. The part is $35.00 for each and you would need at least 2. Then you will need an alignment given you can find someone who can do it.
Lowering looks cool, but I kept mine stock tires and chassy height and this weekend drove 1600 in two days and tires look new. Jim
The Repair bolts replace the stock bolts in the front end it takes 4 bolts.
For the rear one will need adjustable rear links or a Kmac kit to correct negative rear camber as Mercedes does NOT offer anything to correct the Negative Rear camber.
Several shops sell the links...
