Question about 17" Wheels
1. If I only have the standard suspension, is there any degradation in ride comfort? I understand that the side-walls will be shorter and therefore, stiffer assisting in cornering. I am not looking to put on high performance summer tires in favor of a performance all season.
2. Why does the brochure clearly say it is a NO NO? Any reason beyond changing the ride dynamics?
3. If you have done this already, what if anything have you noticed regarding the ride comfort or road noise?
BTW, no aftermarket product has EVER been added to ANY car that was NOT an improvement. Nobody admits mistakes.
I called MB. Explained the situation. From MB technical here is what they said:
The W211 CDI has 16" ET36 wheels for a very specific reason and the setup is different from the gas W211's. For this reason the only wheel they would approve is the one that came on the car. While they admit that the 17" ET38 wheels may in fact work, they do not recommend them. Having said that, they did not provide me anything more specific.
I get a much more responsive firmer ride, My gas milage did suffer a bit...
But it looks 1000% better then the 16 did..
JM
Sometimes MBUSA is a bit misinformed. The EU and US Bluetecs are identical, so as long as it is a factory 17" wheel, you are free to choose.
Also, and more interesting is the fact that in the accessory manual, most of the 18" AMG wheels do not have this prohibition, just notes that you have to roll the fenders.
Wish there was some definitive source on the subject. Would like a nice set of 17's for summer but in no way do I want to do anything that will create a problem for my car.
Jap tires have a lot of comfort and balance. Id take Bridgestone Potenza g3, yokohama or falken over michelin. My ride quality improved 50%.
I would suggest that you go with either a 17 or 18 inch MB factory set with OEM spec tires and you will be fine. The 17's won't ride much differently, the 18's will be a little harsher, but will track and corner more precisely.
Go with what suits your needs/taste and post some pics.
http://www.mercedes-benz.de/content/...ne_Typ_211.pdf
