E-Class (W211) 2003-2009
Airmatic Problem
Old Oct 29, 2007 | 06:08 PM
Tariq's Avatar
S500 W223 2021
Airmatic Problem
Note that I have E500 , 2003 model, today in afternoon I stopped the car while the Airmatic system set in level one (one Red light) in the evening I take it off to the comfort mode, but while driving I got this error message in the instruments cluster, however I drive the car normally without any problem, but I feel if I need to adjust the level like rise or lower the car , it seems its not working.
Dose any one face the same.
Old Oct 29, 2007 | 09:37 PM
georgedaman's Avatar
GL350
yes several times..mine was pinched wiring at the right rear shocks
Old Oct 30, 2007 | 10:43 AM
GeorgeThompson's Avatar
Silver 2004 E500 4Matic
I have the same problem now. I get the message every few days, but nothing seems to be wrong. Afraid to take it in because it looks to be an expensive problem.
Old Oct 30, 2007 | 12:00 PM
Diesel Benz's Avatar
I would assume it would not go lower by time. Shouldn't you let the dealer at least read the fault codes?
Old Oct 31, 2007 | 12:49 PM
Yea thats true. I actually have a D+ service coming up in 4000 miles. Was trying to wait so they could do it then.
Old Nov 3, 2007 | 05:41 AM
Tariq's Avatar
S500 W223 2021
Well By the time the car wont get lower after you get that message, but if you parked the car for more than 6 houres u will find the car lowered in all wheels, but it rise very slow,, that because of the pump which in front left side, it cost arround $ 250 , its same an Air pump , note that you need to change the fuse too which is already expierd after that part got a fulty , that fuse is orange and it located under the gloves in the right side.
I already fix mine and its ok now.. any one wish to get my help am at your service
Regards
