E-Class (W211) 2003-2009
Keyless Go Problem
Old Nov 26, 2007 | 03:35 PM
mr.louie's Avatar
Mercedes 03 E500
Keyless Go Problem
My 2003 E500 fails to start intermittently with the Keyless Go. All lights turn on, it will start with the key, but not with the Keysess Go button. Has anyone else had this problem? I took it to dealer, and they changed my key battery. It seemed to work for several weeks, and is now doing the same thing-not starting intermittently. Would really appreciate any suggestions before I take it back to the dealer.
Old Nov 26, 2007 | 04:09 PM
MB500's Avatar
2021 Tesla M3SR+, 2017 GLS550, 2011 E350 Bluetec, 2007 GL450 (GONE), 2003 E500 (GONE)
The keyless-go receiver maybe going bad. See if the dealer could re-flash the firmware. If not, you may need to get a new one. It's located under the left trunk liner and sits on top of the NAV bracket.
Old Nov 27, 2007 | 12:27 PM
JDM_SXE-10's Avatar
2003 E500
Issues with intermittent Keyless Go functions are usually an indication of weak batteries so that may be something that you should try first. It's possible that the batteries need replacing again.
Old Nov 27, 2007 | 01:08 PM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
I had an issue w keyless go, when the red message light came on the instrument cluster that read "Key not recognized". It went away one i repositioned the key from the ashtray.
Last week, I received the message "Low Battery in Key". Went to the dealer and paid $18 for an overpriced battery.
Old Nov 27, 2007 | 04:12 PM
Barry45RPM's Avatar
2015 ML 350
Radio Shack. Less than 1/3 of what you paid, but no free coffee.
Old Nov 27, 2007 | 06:52 PM
bigmel's Avatar
2004 E500 4matic
don't forget the donuts and bagels...
Old Nov 27, 2007 | 08:39 PM
pinebaron's Avatar
07 E320 Bluetec
I had exactly that problem on two consecutive days when parked next to the same car at work; then I read in the manual that spurious radio signals emitted my sources other than the key may interfere with the key, this is not a malfunction. Next day I started parking my car in a different spot; never had a problem since. Low battery condition is usually displayed on the dash.
Old Nov 28, 2007 | 12:47 PM
perullo's Avatar
2012 CLS63
Not true - easy fix!
I've had the same problem - big pain in the ***. I had mb replace my battery for $20, nothing. I suspected the contacts after taking out the batteries and noticing how loosely they fit. Today I jammed a dime between the two batteries and crammed the key back together (wont quite fit with a penny).
Voila.
Problem solved!
Old Nov 29, 2007 | 12:31 AM
Barry45RPM's Avatar
2015 ML 350
Why not just bend the contact springs?
