E-Class (W211) 2003-2009
Wheel help
Old Dec 13, 2007 | 05:44 PM
fdee's Avatar
04 E500
Wheel help
Greetings....
New to the forums and first post here. Just acquired my first Mercedes (2004 E500 sport). In the market for some new wheels. 19's or 20's. Can someone tell me the proper offset for my model? Also, best tire sizes?
many thanks
Old Dec 13, 2007 | 07:25 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i'm sure this has been covered numerous times...
19x8.5ET30 245/35R19
19x9.5ET35 275/30R19
20x8.5ET29 255/30R20
Old Dec 13, 2007 | 08:36 PM
fdee's Avatar
04 E500
Much appreciated!
Thinking of a staggared set up. Any benifits going staggared or strictly for looks?
F
Old Dec 13, 2007 | 08:56 PM
gnma's Avatar
'12 Mustang 5.0, '89 Supra Turbo, C55,
Originally Posted by fdee
Much appreciated!
F
Staggered setup helps the rear wheels put the power to the ground. With 339lbs/ft of torque starting at 2,700 rpms, you can rest easy knowing you did not get the staggered setup purely "for looks".
Old Dec 13, 2007 | 09:05 PM
reyzbenz's Avatar
2005 E320
Can the sizes goes with 2005 e320 also? is 19 better than 18 so I wont loose a lot comfy ride like the originals?
Old Dec 13, 2007 | 09:57 PM
fdee's Avatar
04 E500
Sounds good!
much thanks
F
Old Dec 13, 2007 | 09:58 PM
noyu's Avatar
17 E43, 18 GLE400
If I'm not mistaken the staggered setup also reduce oversteering by induce understeering to the car (narrower front tires).
There are pros and cons on staggered setup such as you can't rotate the front and rear tires, slightly reduce in gas milage, some said slightly slower in speed pick up due to higher friction (but some argue you got better traction off the line & less tire spin so its actually quicker).
I think the offset is still compensated by the hot looking (I would do the staggerd setup too if I'm changing the wheels)
Old Dec 14, 2007 | 09:46 AM
psoas's Avatar
09 jeep srt8, 07 gl450
front 19x9 et 35 255/35-19 mich pilot sport a/s tires
rear 19x9.5 et 35 285/30-19 mich pilot sport a/s tires
currently on 2005 e500 sport, driving in sport 2, no rubbing and looks great
hope this helps.
dave
